Hi All,
There are a few threads regarding cleaning the outside and inside of your Prado but i haven't found a great deal that relates to under the bonnet.
After my last few trips i have found that the amount of dust and mud that is getting up in there is now to the point that i find it hard to read the D4D tag on top of the motor.
I am a bit dubious to just go blasting in there as with a previous car i had, i was told to spray the engine bay with diesel then spray it with a gerni and soap to clean it. By doing this i ended up with a fantastically clean engine bay devoid of oil, dust and a number of other horrible looking things but also a car that wouldn't start as there was water in important places such as the distributor cap.
What do you use to clean all the grime out of the engine bay and are there any things that you shouldn't blast with the water and whatever other chemicals that are to be used?
I want my engine to look as clean or close as i can get it to the exterior and interior of the vehicle.
Please indicate what motor you are talking about when you reply as we don't want anybody spraying the wrong bits.
cheers
Muddles
cheers
Muddles
