another reason for a front locker lol
Disabling traction control on the Prado
Originally posted by Brett1979 View PostMy traction control annoyingly kicks in when driving up really steep hills even with the rear diff lock engaged. As soon as a front wheel let’s go slightly and part spins the traction control kicks in & stops me. Frickin annoying. Just an example of technology aids being a real hindrance when off-roading. I’m keen to give this a go.2018 150 Series Crystal Pearl Prado VX 2.8l. 2 inch King springs and Bilstein shocks, Airtek TJM snorkel.
Originally posted by cuda View Post
I have been driving up some pretty difficult slopes and as long as I keep steady throttle applied, the wheel spinning stops and applies power to the wheel on the ground. Never had it stop me advancing. Maybe its to do with the stability control being active?
Who knows. It’s a weird one and something that is a handicap that’s for sure. The dash light indicated the VSC was disengaged. Another thing is my garage slab has a 15mm step up when driving into it from the driveway. If I drive in gently, accelerating from a stand still over the lip and if the car rolls back gently down the lip again & I touch the accelerator during this process the traction control noise kicks in and I can’t drive the car forward again unless I press the brake pedal for a split second or give the accelerator a decent stab. If this is normal its very annoying. I generally have to drive in gently because I’ve got only 5mm of clearance between the top of my side awning & the garage entry.2018 150 Series Crystal Pearl Prado VX 2.8l. 2 inch King springs and Bilstein shocks, Airtek TJM snorkel.
- 1 like
General rule of thumb: If your traction control is engaging in soft sand, your wheels are slipping. If your wheels are slipping, your tyres are not deflated enough.
