how to dry the carpet in my prado???
  • how to dry the carpet in my prado???
    How do I dry the carpet in my prado??? I found out the hard way that they leak water into the cab floor the hard way today when doing a creek crossing :roll: . I have toweled it as dry as I could and have had the heater on and the fan flat out on the floor but am wondering if I need to pull the seats and carpet out I was also going to try and get some thing under the carpet to lift it up a inch or two so air can get under it. It is only the floor that is wet as there was about 20mm of water in there.
    Brenden
    [color=#FF0000]ECB ally bar, IPF HID upgraded, dual battery with CTEK dc to dc inverter, 32lt Engel, Safari snorkel, GME UHF, Maxtrax, bridgstone duelers, Offroad camper Trailer [/color]
    [color=#0040FF]WISH LIST: lift kit, Onboard compressor,recovery points [/color]
    Re: how to dry the carpet in my prado???
    Hire a carpet cleaning machine that will suck up all the water
    OR
    Get a carpet cleaning person to do it for you.
    If it were me, I would take the carpet out, dry the floor and have the carpet cleaned as above.
    October 2003 build GLX Prado Diesel. Nudge Bar, window tinting, fitted sheepskin seatcovers, bonnet protector, cargo barrier, sandgrabba mats and empty pockets.
    Retired Nt Police and now TPI
      I would bite the bullet and take the seats and carpet out.
      We've had a few of us take a swimming lesson ..... and the main lesson learnt is to take the carpet out and let both the underlay and the floor dry out properly.
      (Thanks to Jeff S and Fishnut for their swimming pics)
      Chippy
        Brenden,
        yep take the carpet out, its the only way you will get it properly dry and clean. While the carpet is out check that all the bungs in the holes in the floor are present and seated properly. Prados are quite water tight and you shouldn't get any water entry into the cab unless you stop in the water. I've taken mine "swimming" a number of times and have never had any water entry.
        EX-Prado Owner
          Thanks guys looks like I am pulling it to bits! with only 7500km on the clock and two months old :roll:
            Where are the photos?
              Very interesting to note tha the bung/blank grommet Chippy has identified in his photo above was dislodged in my car which at the time was only 5 months old (when I noticed it) and had been off road twice. I was taking a sticky beak underneath after cleaning and noticed it :shock:
                Ok guys I have the carpet out and drying now and was wondering if it would be a good idea to silicon the plugs in so they cant be dislodged or is there a good reason they are easy to get out??? I also noticed that the door seal is just sitting there not really locked into place and thought it might be a good idea to silicon it in aswell?? I could see the hole that the dealer was taking about in under the kick baord and it is bid enough to put a coke can though but once again it must be there for a reason :? Also all of the Bungs were in place and seated well. Thanks for the help with this topic and sorry about the double post just thought that one was about drying and the other was about how to stop it happening.
                Brenden
                  MDS, Brendan,
                  the bung photo was mine (it's from one of the WA powerline trip threads I think). The reason I highlighted it was because it was completely dislodged. Surprise, surprise, I could also see where all the mud had come in through it. I have no idea how or when it got dislodged, because I've done bigger water crossing than the one that drowned the carpet with no probs. My suspicion is that I pushed it in with the high-pressure sprayer when cleaning too enthusiastically :lol:
                  So Brendan, I did seal all the bungs with black silastic. Can't see any reason not to.
                  MDS, I reckon it would be hard reseating it without pulling the carpet too!
                    Originally posted by fishnut
                    MDS, Brendan,
                    ah thanks for the clarification. I pulled the grommet back through the hole in inserted it from underneath which in one way is good because it won't get pushed in easy but on the other hand may get caught by sticks or similar and get pulled out.
                    Re the "enthusiastic" pressure washing, that may have been my cause too now come to think of it.
                      Cheers fishnut looks like I will give them a quick lick before I put the carpet back in. luckly for me the water was very clean and no mud come in so all I had to do was dry not clean aswell
