aircon belt removal
  • aircon belt removal
    im of to Queensland tomorrow but this morning i noticed that something has gone amiss in my aircon main motor,its making a sound as if a bearing or something like that has shat itself inside.im just wanting to find out can i simply remove the belt and have it repaired when i get back [2 weeks] without having this causing any other trouble,it looks as though the belt dosent affect anything else.also if anyone has replaced one of these before some sought of costing that i may be up for would be good. shane.
    2004 3.0TD,sov bar,projecta compressor,rear camp table,rear seat cargo net,and big wish list.
    Re: aircon belt removal
    The belt only runs the aircon so it's ok to remove. Tension is removed at the idler pully.
    It's the other two vee belts that run the vitals (alt/fan/water pump)
    If you can isolate the noise to the clutch mechanism you may be in luck as it can be removed from the front without dismantling the pump.
    Mick
      hi Mick,
      thanks very much you have given my wife some piece of mind and i will be setting of to Queensland with no air con in the morning.its meant to be 40 odd degrees tomorrow.lucky ive got the old fail proof windows. shane. ops:
        aahh yep the old back-up aircon, it's called 4wd100... 4 windows down @ 100 klm/hr
        150 on order ??
