REAR DOOR PANEL REMOVAL
  • REAR DOOR PANEL REMOVAL
    Tried a number of searches, ( no luck )
    for info on the rear door inside panel removal.
    Whats the secret to removing the thing without damaging the dam thing,Or me for that matter .
    All advise greatly appreciated
    Santika
    Re: REAR DOOR PANEL REMOVAL
    Hi Santika,
    The info is actually in the GPS TPX09 thread somewhere, but from memory, remove the two screws in the inside door latch recess (there may be another one behind the toolkit), then gently pull at the edges all around, so it comes out of the clips.
    Confidence - The feeling before you fully understand the situation
      Hi,
      Santika as Dave wrote, there is one hiden behind the tool kit, also I found the bottom ones to be very hard to remove,
      one or two broke so might be worth getting a couple of spares before you start.
      Also be careful of the trims running beside the window, if you pull the bottom of them out you might break
      the pins and when pushing them back in be careful as the clips in the metal work have a habit of pushing
      through and falling down inside the door.
      On my car I found the pin broken on the left hand trim, I didn't force it and I have never found the missing
      clip so I suspect it was broken when the car was built.
      LeighW
        Dave an Leigh, thanks for the reply.
        All done,
        And Yes,, i did manage to break some clips... Bugger 4 in all ops: ops: ops: ops:
