G'day one and all, new to the forum,, long time reader first time poster.
I am posting this for your information and a warning to check your engine mounts if you hit the tracks on a regular basis.
I have a major problem.... I started to notice a ticking sound from the engine bay when I started the 2005 GXL V6 auto up in the mornings and on closer inspection it was the fan hitting the radiator cowl making the noise. What was more concerning was that it appeared that the engine had a slight lean on it. I took it to the dealer and when we got it up on the hoist we found that the passenger side mount has collapsed into the rail :shock: , the drivers side is cracked but I am assuming that that is only because the engine has been relying on the one mount for some time. The only thing that was stopping the engine falling out was the diff.
Estimated repair bill $4500 - $5500 :cry: Pictures have been taken and sent off to Toyota but I am not holding my breath as far as any compensation is concerned but will keep you all posted. .. The first image is the driver side mount you can see where it is starting to rust where it has cracked..... The second image is the passenger side the gap between the rail and the mount is around 8mm it is like the weld has just popped. :|
I know I have had my truck on some rough tracks and I bottomed it out once pretty good on Googs Track towing my KK at xmas but at the end of it this thing is supposed to be built for offroad and for the record I am running the billy/ridepro system by ATS & copper STT's
The 64 million dollar question :?: ...... has anyone else experienced this problem.
John
John
