Re: Fording depth and what to look out for?
Got this respone from Toyota today, only took 2 weeks:
Thank you for your response.
Fording depth is at 700mm.
With relation to the clutch, It is difficult for any manufacturer to comment on the life expectancy of any component.
Each part in a vehicle is subject to many conditions over which Toyota have no control, i.e., environment, road conditions, driver technique, maintenance, etc.
These items may have and adverse effect on a motor vehicle and, of course at some stage in vehicles life components will need replacing and/or repairs.
As per the owners manual, if driven through flooded road conditions be sure to have your Toyota Dealership check the following:
• Brake function
• Changes in quantity and quality of oil and fluid used for the engine, transmission, transfer, differentials, etc.
• Lubricant condition for the propeller shaft, bearings and suspension joints (where possible), and the function of all joints, bearings etc.
Thank you,
(name deleted)
Customer Experience Consultant
Customer Experience Centre
Toyota Motor Corporation Australia
Ph: 1800 252 097
I don't like how they worded this "As per the owners manual, if driven through flooded road conditions "
So if driven off road is it covered?
• Brake function
Thank you,
(name deleted)
Ph: 1800 252 097
