Originally posted by tez1
View Post
Water on floor of vehicle after rainfall
When we had a 3 Rhino Sportz roof racks fitted when we bought a used 120 about 5 years ago the Toyota dealer fitted them as part of the deal ,
It rained pretty heavy in the first week of us owning it and we noticed the front seat belts felt cold , and on inspection we discovered they were wet , and the carpet on the floor directly below the seat belts was also wet ,
I took off the clip-on frame lining and it was very wet ,i left linings off and went back to dealer and they removed all racks with the special "T" spanner , which exposes the roof mounting screws , cleaned roof channels and found the front rack mounting screws didn't have correct plugs(a couple of green ones) so correct ones got fitted ,
when I got car home I removed the racks and put some Sikaflex roof and gutter over the screw holes and plugs then replaced the racks , and left the linings off the inside for a week and dried the carpet out with a heat gun , next time it rained I checked no more leaks and none in the last 5 years , cheers john
Originally posted by jmichaels View Post
I would like to remove the roof rack. Can you either explain how to do that OR can you point me to a video? Thanks.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
