Cost of 160k service
  • Cost of 160k service
    Rang Toyota and 2006 d4d 160,000 service will be in excess of 1000 dollars. So the intank fuel filters need changing along with general service is the reason for the cost. Does this sound about right? Stated there was about $600.00 in parts. I have picked myself up off the floor cheers Brian
    Cheers Brian. 2006 Grande D4D
    every 40k service interval are the major ones, diff and transfer case oils, amongst other things
      Thanks blw. I thought I might have received a few more replies but $1000.00 must be a reasonable price ?
        If servicing through Toyota, they charge around $800 to $1000 for the $40k, 80k, 120k, 160k 200k services typically.
        Its worth ringing MIdas, Ultratune or your local mechanic for a log book service quote as you will find they are significantly cheaper than the Toyota dealerships.
          Thanks blw. I have had dealings with those chain store type service centres and have not been impressed. They seem to be always trying to sell you “extras”. Have done a lot of my own servicing over the last 20 years but am now restricted in movement. I will give Toyota a go this time and see what happens. As long as they do the job that you pay for is about all you can expect. Cheers
            Just as a follow up I was happy with the result. Two things stood out though They did a diagnostic check and didn’t charge me $160 normal fee. WTF. They could not or would not fix the after market indicator attached to the bull bar as they did not have an auto electrician plus I think because it was not a genuine Toyota part. I would have thought a diagnosis check would be part of a service. How would they know if anything was faulty? Never mind overall happy
