Hi all. My 120 has developed a squeak or chirp noise from under the dash. Definitely electrical. But seems to have no pattern. Ie cold or hot, towing or not, braking or accelerating. Originally thought it might be the brake controller but speaking to Redarc they say there are no components that would generate an electronic “squeak”. Cannot identify with any certainty. No code errors showing up. Anyone else had a squeak or chirp.
Squeaking noise under dash
I've got a squeaky chirp that sounds like something chirping in the dash but I think is one of the driver doors exterior trim mounts being broken...when tapping the trims is clear its looser than the others...I'm going to pull the trim off and remount it in a month or two so I should be able to report back then...
This worked for me! unbelievable I know, but it worked. The chirping was constant even after my mechanic was asked to fix it along with misfiring issues. Got it back running well but still chirping. I figured there were no errors showing anymore which is why they gave it back still chirping.Originally posted by Weeman View PostTry turn your air temp all the way to hot and back to cool again i have similar noise and thats how i get mine to stop
I read Weeman's post, turned the heat up to high and back down again and haven't heard a thing since. So grateful! Thank you!
