Hi all,
Probably easiest to see below, not sure if Razorback81 is very active on here anymore
Any advice appreciated - hopefully this is enough info
(08 120 diesel)
Originally posted by Razorback81 View Post
yes it has quite some tension
trying to keep that much belt in tension needs a reasonable amount of force ( i think mine is 2.3m long with the endless air pump fitted )
the pulley you need to use is the one at the bottom
( 3 smaller pulleys almost vertical above each other )
it is 15mm socket ( i just went and checked mine and tried the direction for you )
and turn it towards the battery to loosen the tension on the belt !!
my question below, thanks;
Hey mate, I know this is old thread but.. when I try this the nut on the tensioner pulley comes loose and starts to unscrew??
(08 120 diesel)
