Hi, just under 3 months ago I bought an 07 GXL petrol 35,000 klms.
It has developed a real metalic clang a few meters into a reverse, only in reverse, distance till clang is variable - 1 meter to no more than 15 meters. Can be from stand still over night or simply reversing into a parking space at the shops.
I called the warranty dept at Toyota dealer and they say its normal for prado, is rear brake pads moving into new position with change in rotation. It can be a pretty damn loud clang and considering it wasnt there initailly quite concerning.
I called a 4WD specialist and they said they have worked on plenty of Prados with no reversing clang noise. I took it to an Automatic Trans specialist thinking it was in the trans and they found that the handbrake needed serious adjustment and RH rear brake needs work (not sure what that meant, maybe sticking calipers) and were fairly certain it was the brake pads making the noise but wothout stripping things down couldnt be certain.
They also said it has excessive gear noise coming from transfer case what ever that is.
Does any one else hear a clang? Any suggestions about gear noise from transfer case?
I am taking it into the dealer Tuesday (3 month warranty runs out wednesday
)and if im going to get the runaround Id like to have some qualified opinion behind me.
D
D
