Fuel tank breather maybe????
    Re: Fuel tank breather maybe????
    interesting mod.
    No harm in doing it, and could save you hassles down a track somewhere. probably not needed for tarmac shopping trolleys, but for us offroader types probly needed.
    When I open my fuel filler cap(diesel) after driving, I get a rush of gasses out of the tanks.
    So I would guess that valve would slowly let gasses/ pressure out (like over an hour or so after driving) and also let air in as fuel is used or cooled.
    Or even as fuel/ gasses expand and contract during the day night hot cold cycle.
    good one.
    Jeff.
    W. C. Fields (1880 - 1946)
      Just completed this mod also!!! Found my fuel tank breather CLOGGED with dirt - jammed open... :shock: :shock: :shock:
      I could easily blow air though both ways - until i soaked the unit in water and cleared the obstruction!!!
      Went from this...
      To this...
      Matt
        Anyone confirmed if this is Diesel only yet?
        I have to crawl back under mine to replace the breather I fitted to the rear diff - idiots at Enzed sold me a union and despite asking three times for them to confirm it was 1/8 BSP (which they did each time) it wasn't!!! Got it replaced today so while I'm under there I will have a look for the fuel tank breather and report back.
          I'm surprised anyone went to the extent of removing it in the first place. The second post by MickL stated what it is. A check valve is a one way valve for air or fluids. :P
          [b]2000 Prado RV6[/b] ~ TJM Type 15 Steel Bullbar ~ Uniden 400SX-RM & GME4702 Ant ~ Front Tow/Recovery Hooks ~ ARB Recovery Kit ~ ARB CKMP12 Air Compressor ~ DIY Rear Door Trim & Table ~ Extended Diff Breathers ~ Safari Snorkel ~ Wireless Reverse Camera ~ Iron Ox Full Length Roof Rack ~ Looong Wish List ...
            Mine was jammed with dirt and freely passed air both ways until i soaked it in a bucket and cleared the muck from inside the valve! Now it works as it should again, and moved to a new location to prevent it happening again...
              Just to confirm for anyone interested, this breather isn't fitted on the Petrol version (well not on my 2006 GXL anyway). As Mick says, the line runs all the way to the charcoal canister.
                thanks Trekrider for the info, i was about to do it this weekend my todo list is (-1).
                hisham
                [COLOR=blue]2006 VX ,5 Auto , currently Scan gauge II , Bonnet Guard ,wind deflectors,head lamp cover, dust deflector,insect net , Engel fridge,IPF fat boy,Hella FF300 lights,Toyota HD bars,BF 265/70 R17 A/T, Hella TPMS, K&N,OME 2",DBA , AirLift 1000 & Wirless Air control , ARB Comp,Safari Snorkel.[/COLOR]
                [URL="http://www.fuelly.com/driver/hisham/prado"][img]http://www.fuelly.com/smallsig-metric/52690.png[/img][/URL]
                  hisham
                  No worries my friend, nice to be able to help someone else for a change
                    Matt,
                    Taken your lead and finally had the time this afternoon to do the mod. Easy one to do and I managed to push the valve body to the very top. Although I couldn't get up the very top to secure it with a zip tie I locked it in place between the filler pipe and body firmly giving me maximum hight.
                    Here are some photos.
                    http://s5.postimage.org/xxvtv976v/IMG_2097.jpg
                    http://s5.postimage.org/ma1s0pi1z/IMG_2247.jpg
                    http://s5.postimage.org/llsxhrjc7/IMG_2250.jpg
                    http://s5.postimage.org/pwc6r3dt3/IMG_2254.jpg
                    http://s5.postimage.org/3lobr4giv/IMG_2252.jpg
                    http://s5.postimage.org/eb20jdsbr/IMG_2256.jpg
                    http://s5.postimage.org/5er8fg1pj/IMG_2251.jpg
                    Note when re installing the valve there is an arrow and the word Tank so be sure you put it on correctly (see image below).
                    http://s5.postimage.org/8o5nlwpt3/IMG_2095.jpg
                    Hope this helps someone. Worth the effort as you can see the amount of dirt that come out of the valve. Inside there is a very small hole so you can imagine how block it was.
                    Hazza
                    Hazza
