Flexi Tank Install
  • Flexi Tank Install
    Hi All
    Tried searching for info on the install of a FlexiTank Bladder.
    These Bladders are fitted behind the trim moulding in the rear right cargo area.
    Any info or links would be appriciated.
    Regards Troy
    Tried fitting one of these many moons ago but found didn't fit
    my GXL with dual air.
    LeighW
      Here is one to start you off Troy. http://www.pradopoint.com/showthread...anks-for-water
        Troy, the biggest issue I've heard with people having these (120, 90 and other vehicles) is how to fill them up. Some people have found the only real way to do this is to open the little popout windows and put in a filler hose and the fill from there. They are supposed to be a real bugger to fill due to the access to them. I havn't heard of the same issues with the boab style tanks or the floor mounted tanks as they are a lot more accessible.
        Take my comments with a pinch of salt. I don't have a flexi bladder.
        Schaffer
        Addicted PP Member
        [COLOR=#000080]Nick[/COLOR]
          Thanks for the replies Gentlemen.
          Cheers Troy
