Re: DIY Boost Gauge for $60
If you have plumbed your gauge pre venturi/butterfly plate (intercooler side) then you will not see any vacuum at all read on your gauge.
If you plumbed it post venturi/butterfly plate (manifold side) you will see approx 5-7 in.Hg at idle and maybe between slow gear changes in a manual also sometimes during decelleration. 5in.Hg is a very small negative pressure (look at the scales on the gauges shown in this thread)
Diesels generally don't run a throttle plate hence no intake vacuum.
Some like the 1kz and d4d are an exception to this rule. They run an intake venturi/butterfly to create a small vacuum at idle to draw in large amounts of EGR gasses to meet emissions standards.
Mick
I like to know if you guy's get a vacuum reading on the boost gauge? If no, why is that?. I got one installed on my 1KZ-TE, and one of my mate ask me how come my boost gauge doesn't read vacuum?, and I just answer maybe its just a diesel engine different from a petrol engine. Just want to really know what the answer is. Unless there is something wrong?
Mick
