Was wondering if anyone has tried to do this mod, by installing a aftermarket starter button!!! Looks awsome on 150series!!!
BUTTON START
Re: BUTTON START
No, but I've got a key. The two disadvantages of the key in my opinion is that when you go over rough tracks if bangs around a lot which makes noise and has resulted in scratches in the trimming around the key whole from the other keys and the other issue is the battery going flat, but that is still an issue with the 150.Originally posted by MOWYAWas wondering if anyone has tried to do this mod, by installing a aftermarket starter button!!! Looks awsome on 150series!!![COLOR=#000080]Nick[/COLOR]
Re: BUTTON START
lol Glad I'm not the only one.Originally posted by ragsBut the 1 advantage of a key is that you can still use it to scratch your ear,i'm for the key
Russ[COLOR=#000080]Nick[/COLOR]
Re: BUTTON START
Wouldn't buy a used Prado from you! :P :P :POriginally posted by ragsBut the 1 advantage of a key is that you can still use it to scratch your ear,i'm for the key
Russ
AJ[i][size=2][color=#008000]2008 D4D GXL Auto [/color]- [u]BLACK[/u][/size]
[size=2][color=#0000FF]- ARB Deluxe Bullbar - TJM Airtek Snorkel - Pirhana Dual Battery - BFG A/T's - Waeco 60L - Canvas Seat Covers - LED Spotties - Bilstein/Ridepro Lift - TJM Bashplate - GME TX3440 UHF - Rhino Roof Bars - Rooftop Tent & Awning - Poly-Airbags - ScanGauge II - Beaudesert 2.75" Exhaust - ARB Twin Motor Compressor [/color][/size][/i]
Re: BUTTON START
The length of their legs!! They need theclutch fully depressed or the brake fully pressed to be able to start the manual or auto respectivly.Originally posted by switchedSo what stopping a kid sitting in the front seat pushing the starter button when the mum/dad at the rear of the car putting in the shopping?
It is a well thought out system.[size=2][color=#4000FF]2009 GXL D4D Manual
[/color][/size]
Re: BUTTON START
Make that 4 :lol: and using a push button starter is old technology.Originally posted by DobboMake that 3 :lol: And it's also good for opening parcels that are sticky taped shut :wink:Originally posted by ragsBut the 1 advantage of a key is that you can still use it to scratch your ear,i'm for the key
Russ07 Upgrade GXL D4D, Manual, Dune,Sov Bar, BFG's, SG11, Redark dual Batts, Extensive Aux wiring, Stebel, LED stop tails, IPF HID's (my mod), 240V Inv, ARB Comp, GME UHF,TPMS, Safari snorkel, GPS,Hilux washers, 40l Engel in 30% pas pos,homemade A/C cond protection plate, polyairs.
Re: BUTTON START
And if you don't fully depress the clutch or the brake and press the button, it is basically swithching through ACC - ON - OFF.Originally posted by mcsumwayThe length of their legs!! They need theclutch fully depressed or the brake fully pressed to be able to start the manual or auto respectivly.
Re: BUTTON START
When my key cracked, I replaced it with the flip out version that was mentioned in a thread here and is from an ebay seller. Since then, I have always had the Prado key by itself and house keys etc in a separate bunch. The good thing is that I only carry the car key with me when I'm out and no jingling of keys on the ignition trim. The bad news is that I sometimes forget the housekeys in the car and have to open the garage door, unlock the car, reach in to find the keys and then walk back to the front door (sometimes I forget to shut the garage door until I head out again the next morning but so far, nothing's been taken).Originally posted by SchafferNo, but I've got a key. The two disadvantages of the key in my opinion is that when you go over rough tracks if bangs around a lot which makes noise and has resulted in scratches in the trimming around the key whole from the other keys and the other issue is the battery going flat, but that is still an issue with the 150.
Re: BUTTON START
im for the key also..
personally i think its a mod thats a waste of time , it may look cool but a not worth the bother in the 120...
joeyFeatured - issue 140 Australian 4wd Action.
-issue 52 Modified 4wds .
