Rear Camera
  • #61
    :lol: Actually, the way some people tailgate, I'd love to hook up the reverse lights to switch on...... either that or one of those flashing signs that say "Hey Stupid, Back Off, I'm not that kind of Guy :twisted:
    White '04 GXL Auto with
    Breadboard wheel spacer (as recommended in Pradopoint)
    Hilux Washer jets (as recommended in Pradopoint)
    Bosch Wipers (as recommended in Pradopoint)
    Polaris GPS/Camera/DVD (as recommended in Pradopoint)
    Glovebox baskets (as recommended in Pradopoint)
    Fire Extinguisher (as recommended in Pradopoint)
    Recovery points (as recommended in Pradopoint)
    Flip out key replacement (as recommended in Pradopoint)
    Bilsteins (as recommended in Pradopoint)
    • #62
      Originally posted by Byrnsie
      Originally posted by McBAIN
      I also tried to wire an additional switch that allows me to turn on the camera when not in reverse. It works but the reverse lights come on at the same time so it really freaks out the vehicle behind you when your reverse lights come on while moving forward. ops: I have obviously done something wrong with my switch wiring but not sure what. Another job for the next rainy day!
      Cheers - Greg (Byrnsie)
      You need to put a diode in the line from the reverse light to the camera. This will allow current to flow to the camera when the reverse light comes on but will block the current flow back to the reverse lights when you turn the switch on. Get a diode which has current rating greater than the maximum current that is drawn by your reversing camera.
      Jaycar has a 3 amp general purpose diode Cat no ZR1014 for 25 cents.
      http://www.jaycar.com.au
      Make sure you put the diode in the right way around. There is usually a band around one end and you connect that end to the camera.
      Firey
      Prado GXL D4D Manual. Sovereign bull bar. Tow bar. Head light protectors. Bonnet protector. Insect screen. Cargo mat. Scanguage II.
      • #63
        This is what wannawodka wrote in an email to me when i pm him about reverse camera, might be an idea to talk to him about it he is very helpful.
        Hi Adam
        I have no problems with the over-ride at all. All I've done is fit a two position (both active) switch (Narva brand) so I can toggle between a normal reverse signal current (green wire in behind the dash) and a live accessory wire.
        When in the position which completes the normal reverse wire signal the camera works normally - image on the sat nav changes when you put into reverse. When the switch is in the other position and draws current from a live accessory it acts the same as the reverse circuit but in completely independant of any reverse signal, so on all the time when the ignition is on.
        I don't prescribe to the advice you've received - as far as I know the unit will switch 'alt monitor mode' if it receives a live current and has nothing to do with the GPS function.
        2006 TD Grande
        ARB Winch Bar. Rallye 4000's
        GME TX 3400
        BF Goodrich 265/65/17
        • #64
          A diode in line fixes the problem, thats how mine is done.
          • #65
            that looks almost exactly like the one i got! ebay job? picture any good?
            nice one, i was toying with the idea of not wiring it to the reverse power and just using a switch to turn it on when i needed it... but would probably find that i don't use it that much in that case!
            • #66
              Hi Adam
              Thanks Addy, (and wannawodka). i like this idea, will subscribe to it i think! another switch now on the list of things to pick up from repco on the way home! may just have to finish up early today!
              • #67
                Firey
                Thanks Firey. I should have posted this question six months ago. Now I know what to do the job will be straightforward as opposed to me trying different options, none of which would have probably worked and would have had me totally p#ssed off at the end of the day.
                Simple advice like this is what makes this site worthwhile.
                • #68
                  Just got my eclipse today about time too, but got a good deal here in australia for $245 including adapter they said i needed it. Thing is there is no green reverse wire with it as alot of you guys seem to have hope i don't need this before i start pulling the car to bits.
                  2006 TD Grande
                  GME TX 3400
                  • #69
                    You shouldn't need the green wire in the later model. As far as I understand anyway. There's nothing hard about the install, just a little time consuming removing all the panels..! Good luck with it. 8)
                    03 Grande V6 4.0L, ARB Deluxe winch bar, XD 9000 Warn winch, Pacemaker Headers, Colour Coded Safari Snorkel, K&N Airfilter, Slotted RDA rotors, 55W HID Hella Rallye 4000 spotlights, Dual batt, TJM comp, TJM underbelly bashplate and custom stainless front bashplates, Extended diff breathers, Reverse camera (Eclipse), Yokohama AT-S, ICON 2.5 adjustable remote resi coilovers(front) ICON 2.5 piggyback shocks(rear), 2" lift airbags, Icom ic400pro, Engel 40L, Custom drawer system, Stainless recovery points, Kimberley MyCube rooftop camper.
                    • #70
                      Reverse Camera
                      Hi all. I am only new to the site and are quite impressed by the content.
                      I am wanting to do a few mods to my prado (Grande) and was wondering if any of you could provide me with contact regarding the purchase of the camera and possibly reverse power loom. mine is an 04 model with #18002 on the face plate. It doesnt have an DISC-AUX swith also (mine only has DISk switch.
                      Any help would be greatly appreciated
                      Mark P.
                      2004 Grande, 4.0ltr Auto, Warn 9000 winch,Lightforce 240 HID,Lovells springs, Sovereign bar, Dual battery, GME TX3400, Safari snorkel,factory tow bar,Reverse camera with overide.Bridgestone D683
                      • #71
                        I know this issue has been talked about a lot. But I still havent been able to find any info or pics of the pre-wired reverse camera setup for the new 07/08 model prados.
                        As of Sept 07 all Prados come pre wired for a reverse camera. Before I pull the dashboard and tail gate apart I am hoping someone on Pradopoint has attempted a successful camera install using the existing wiring who can give me a few pointers and hopefully pictures!
                        • #72
                          me three
                          07 Prado GXL, D4D manual, silver and a fridge with constantly changing beer levels.
                          • #73
                            I finally got around to pulling the rear door trim off my 07 VX Prado. Ive attached pics to show what I found and assume the unused while plug is for the reverse camera. It was the only wiring not attached to anything.
                            Now I just need to work out how to attach a camera to it. Does anyone know if the other end of the plug is available from a electronics store etc, so I can wire up a camera?. I have not purchased a camera yet.[img]
                            • #74
                              If you can get hold of a wiring diagram you should be able to work out if its for the camera or not. They stick lots of unused plugs all over the car for various bits and pieces. :?
                              What colours are the wires going into the plug??
                              • #75
                                I didnt/couldnt see the colouring on the wires due to all the black plastic and tape. But, I have a feeling it is the right one as there were no other plugs or spare wires to be seen. All new Prados (sept07 onwards) are suppose to be prewired for a reverse camera.
