suspension measurements
This is a sticky topic.
    Sorry that should read
    Prado 12/06
    Front Standard: 474mm.
    Rear Medium/ Normal setting 540mm on the grande
    Rear High setting 590mm
    Accessories: ARB Steel bar, Magnum Winch, 2x IPF 900XS lights,snorkel and dual battery.
      Originally posted by PAL001
      Guys,
      Below are my measurements, seems like mine is really low compared to the others :cry:
      Prado 12/06
      Standard: 474mm.
      The front?.
      But then again that is alot of weight for the standard suspension.
      So far the standard dimension is 500ish without that weight.
      W. C. Fields (1880 - 1946)
        Jeff,
        Yeah I know, I think I might have to do something about it !
          2003 TD GX, Soveriegn Bar, 155,000 kms.
          Stock standard suspension.
          :arrow: Front: 520mm
          :arrow: Rear: 550mm (empty tank, no gear)
          :!: It's worth noting that before I left for the Kimberley it looked ok with the camper on, by the end of the trip it had sagged noticeably. My oldish standard springs measure up ok on their own, but with a load on the towball it looks like a Commodore
          2001 HZJ105 Turbo Cruiser
          My Stuff [url=http://paulpickford.com/][u]Here[/u][/url] and [url=http://paulpickford.com/prado/][u]Here[/u][/url]
            Thanks PAL001 and Blokeman.
            Will up date 1st post now.
            Did you get any pics from that trip Blokeman? Hope you had a good trip..
            jeff.
              Guys,
              I just had the thought that ARB trim down or use (used to use???) a shorter spacer in the front body mounts when they fit a bar. Does anyone know how much shorter this spacer is and would having the shortened spacer installed actually effect the height of the guards because the front end has been pulled down tighter on the chassis?
              Any thoughts?
              Paul.
                Havnt thought of that in a while.
                I had heard that they use some sort of spacer there but I thought it was to relieve stress and help the cracking firewall issue.
                Looked under mine the other day and they look toyota.
                Jeff.
                  Just checked measurements on mine.
                  Rear 540mm.. on normal ride height.
                  Front 530mm.. with ARB deluxe bar and Warn XD9000lb winch, Rallye 4000's , underbonnet compressor on King springs.
                  03 Grande V6 4.0L, ARB Deluxe winch bar, XD 9000 Warn winch, Pacemaker Headers, Colour Coded Safari Snorkel, K&N Airfilter, Slotted RDA rotors, 55W HID Hella Rallye 4000 spotlights, Dual batt, TJM comp, TJM underbelly bashplate and custom stainless front bashplates, Extended diff breathers, Reverse camera (Eclipse), Yokohama AT-S, ICON 2.5 adjustable remote resi coilovers(front) ICON 2.5 piggyback shocks(rear), 2" lift airbags, Icom ic400pro, Engel 40L, Custom drawer system, Stainless recovery points, Kimberley MyCube rooftop camper.
                    Originally posted by pcm_120
                    Guys,
                    Any thoughts?
                    Paul.
                    Used to is correct, they have now gone back to the longer spacer
                    Difference was 10mm I think
                    Dont think it would affect the guard, the bar used to fit snuggly under the guard (about 15mm gap) It now has a 25 mm gap
                      Measurements for my 2005 V6 GXL, standard suspension, no bullbar are:
                      :arrow: 525mm front
                      :arrow: 550mm rear
                      Mike
                      2005 GXL V6 Auto
                      8 years of modifications
                        Mike and Blokeman, the heights that you guys have from your vehicles that are a few years old are higher than my new one, are your springs and shocks original, as that is pretty good???? are u measuring from the centre of the hub to the bottom of wheel arch lip/ flare??
                        [b]Rob[/b]
                          Yes mate, dead stock, center of the hub to base of wheel arch....
                          Dear oh dear I think something might be wrong. My GX doesn't have flares, do they hang lower than the steel?
                          edit* Had a look at a new flash one in the carpark this morning. The non poverty pack with flares less than 10mm, closer to 5 below the steel. It had a wireless too...
                          • #28
                            Hutch
                            I carefully re-measured today in better light and got 515mm front and 545mm rear. Standard suspension and a bit less than half full of fuel.
                            Mike
                            2005 GXL V6 Auto
                            • #29
                              Hi Justo, Hows it going.
                              What is your suspension?
                              I notice its Kings but are they 2"HD or HD normal ride height
                              And you rear, Kings as well or still standard?
                              Thanks.
                              Jeff.
                              • #30
                                I have up dated yours mike.
                                And just waiting on a bit of info from Justo.
                                1st post updated.
                                Im going in tomorrow to get my front springs looked at.
                                Will post the results, I dont know if Im hanging around while they do it so dont know if I can do pictures.
                                JeffS
