Suspension Measurements 2
This is a sticky topic.
  • Cheers mate.
    [CENTER][B][U]Matt
    [/CENTER]
    [SIZE=2]
    [/SIZE][CENTER][SIZE=2]
    [/SIZE][/CENTER]
    • Here's my stats:
      2008 Prado 120 D4D as per signature below - Fuel at 1/2, ARB Bar and Dual Batts, Rear drawers and fridge in back etc
      Original Toyota susp in 2008 - F 750 R 770
      Installed OME in 2008 - lot of touring including Plenty, Tanami, Gibb River Rd, High Country etc etc Lots corrugations, quite a bit of towing off road van approx 2.2T.
      Front 884/N140S after 1000km settled to 790, after 100,000km and 3.5years 775
      Rear 896/N142 at 1000km 820, at 100,000km 820
      Rear shocks leaking oil after 100,000km but seemed to be working ok, and have just swapped out all 4 to OME Nitrocharger Sports
      F 90000 and R 60005. Left the springs.
      We'll see how it goes.
      So far so good.
      rhs58
      Ex 1988 Mitsubishi Pajero V6
      Ex 1986 Suzuki Sierra
      • Rear springs done and settled at 825mm with full tanks and 4psi in the polyairs. Front now at 810mm. It hasn't been back for its check up and that won't happen now until we get back from the Fraser coast so I am thinking after a bit of sand bouncing the front will come down a little more.
        The steps are pretty much parallel to the ground so it still looks (to me) a bit nose up, easily fixed with another 3psi in the polyairs but I couldn't be bothered. I think I just got used the to stance of the Toughdogs which were only about 10 mm lower in the front but it makes a difference.
        Compared to the Toughdogs before they died the front is firmer though not harsh and still nicely damped and the rear pretty much the same though I fancy a little softer springing and damping. Again that is subjective as the Toughdogs were adjustable and set fairly firm. I do wonder what the shorter front springs and 5mm spacers would have done though, a little lower but not sure how much, might have to do a static measure and then do the calcs and see.
        Happy with the ride and more importanty the financial controller is happy so what does it matter what I think?
        At least someone has gone to the trouble of welding the front struts this time!!!!!!!!!!!!!
        An interesting point is that the lower joint on the Toughdog struts are a heim or rose joint while the OME are rubber bushed which I guess is more the norm. Felt no harshness associated with the rose joint which is strange because an ex track car I had a while back was rose jointed and on country Queensland roads everyone's fillings would shake loose.
        And finally after asking Polyair if I could buy replacement hose clips a post bag arrived Friday which was a full fitting kit. For nix. Thanks guys very much appreciated.
        • Cheers mj it does look a little nose up, but its fine.
          [CENTER][B][U]Matt
          [/CENTER]
          [SIZE=2]
          [/SIZE][/CENTER]
          • Hi guys, i have been reading this one with interest.
            The shock pictured in the failure here is an old 35mm Bore shock. This is identifiable, as the spring seat locates on inside of the Spring & all of the 40mm Adjustables locate outside.
            Tough Dog have not sold this shock since 2006.
            In speaking to Tough Dog regarding this one, they have told me that since this shock, they have continually upgraded the shock with the Post size now up to 22mm O.D & have then since further upgraded the lower eyelet thickness around the bush to 5mm.
            They did ask me what coil was fitted with the strut?
            Failures like this are usually only seen by us in-house when a spring has been topping out.
            Koni have recently gone down this same Beefing-up route after some failures with the 82 Series front struts in raised applications.
            They will not sell 82 Series for Raised vehicles anymore & will only use the bigger 88 Series.
            We have a bit of a unique setup in the Prado's & Hilux's & place a hell of a lot of stress on the lower posts & eyes on the shocks, this stress goes up further in a raised application.
            Regards, Jason.
            • The springs were TDC974H to suit a steel bullbar and dual battery (AGM). The ride height at the front was not excessive settling down to around 785 or thereabouts from memory. I doubt very much whether topping out was an issue either as the car has not been worked hard and for the 4 months up to failure hadn't been off road. As you can see from post #258 there is very little weld and what weld there was had almost no penetration and was badly executed. Even the other strut had very little weld holding the bits together. Comparing that to the OME replacements there is at least a 4mm fillet.
              Interesting what you say about the part numbers. My receipt shows the latest gear. The suspension was fitted from new (via dealer) in Jan 08. I was going to go to the shop and place the failed strut firmly up the arse of the owner but as he went broke this time last year that will be a little difficult. I spoke with the franchise owner and I guess I could have pushed the point, maybe would have had I known how old the parts were but at the end of the day the susepension was 4 years old and there is no way I could justify anything other than a hissy fit.
              I went to this shop because they offered me the combination of different suppliers that I was after rather than a one stop ARB or TJM shop. The shop was relatively new but had quite a few good references. And was being supported by the original franchise owner who has been around the ridges for a long time and definately knew his stuff. The number of mistakes and poor workmanship from this place I have found astonished me over the years I have owned the 120. Things like a compressor wirded with 4mm wire from the relay to the compressor, relays and fuses just fitted in wherever without any common sense to the wiring. And it goes on.
              Recently been using another shop which does good work. I used to fit everything myself but as time gets harder and harder to find that is a problem. I do know that I have more attention to detail that most and I have the gear and skill level, just the time eludes me.
              • What's the general consensus, at what height at the front do you fit diff drop kits?
                • Originally posted by pjorek View Post
                  Up to 50mm lift is fine, 60mm maybe ok, anything over that and a diff drop is probably needed. My lift is only 50mm but I have a half size diff drop as this gives me about a perfect CV angle.
                  • I take it you manufactured your own 'half size diff drop' AJ?
                      Certainly did.
                        I'm guessing this is above the standard 750mm ie 800mm to 810mm?
                          yes, over standard measurements. in standard form the CV's are angled slightly upwards, with a 50mm lift they are about the same angle but going down, so not much change in cv angles, just direction.
                          • Just got back from the shop that fittet my OME setup. These mesurements are from the rim to guard as stated on the OME warrenty card.
                            Before fittment;
                            725mm fronts
                            730mm rears
                            After 500km check
                            780mm fronts
                            815mm rears
                            Overall very happy with the outcome, product and service
                            Dueler120
                            • Old suspension: 737mm front, 765 back
                              New OME fitted: 800mm front, 815 back
                              Back in soon for delux bar fitting
                              • 08 GX with 2" (TJM XCS),alloy bar (steel winch), bashplate, dual battery, pretty much empty (fuel/cargo)
                                Front = 780 mm
                                Rear = 815 mm
