Suspension Measurements 2
This is a sticky topic.
  • Re: Suspension Measurements 2
    OK Here we go, plus I have including before and after weight (We have free access to weighbridge in Alice)
    Standard, FR 752mm, FL 750mm, RR 784mm, LR 782mm.(I cheated and went to local Toyota dealer and measured one on the lot)
    standard with accessories. FR 735mm, FL 730mm, RR 765mm, LR 770mm
    Body Mount rubbers from bottom of the nut to the bottom of the thread on both front sides is 41mm, in case someone has wound the rubbers up tight as this will affect all the above measurments.
    Accessories. ARB steel winch bar, steel touring rack, roof top tent, dual battery system, cargo barrier, driving lights, UHF, brake controller and all the additional wiring involved.
    Standard Weight: 2165 Kgs (includes 180 litres diesel and 3 occupants)
    Accessorised Weight: 2440 Kgs (includes 180 litres diesel and 3 occupants)
    So the above accessorys have added 275kgs so far. :shock:
    Live One Day at a Time for Tomorrow May Never Come
    Build Up: [url]http://www.pradopoint.com/showthread.php?15022-FC-s-120-D4D-GXL[/url]
    Toyota Prado D4D-SOLD; now a 2014 Landcruiser 200 Altitude, Holden Colorado DCab [url=http://www.fuelly.com/driver/effiec/colorado][img]http://www.fuelly.com/smallsig-metric/48073.png[/img][/url]
      hmmm might be time to get some lift under there FC or ya might get some gravel rash on ya guts :lol: . cheers samo
        ARB Steel bar, dual batteries, 4.0 V6.
        Front - 760cm
        Rear - 820cm
        With both tanks full, unloaded.
        Front looks low cause the rear is so high :?
          Bilstein PartNo's:
          BE5-A713 - FRONT (Circlip on middle groove)
          BE5-A712 - REAR
          Kings Raised springs:
          KTFR-101 - FRONT
          KTRR-102 - REAR
          Accessories:
          ARB Steel winch bar (no winch)
          Before Lift (with 85 L of fuel)
          FD: 740mm
          FP: 738mm
          RD: 775mm
          RP: 775mm
          After Lift:
          FD: 810mm (= +70mm)
          FP: 807mm (= +69mm)
          RD: 825mm (= +50mm)
          RP: 827mm (= +52mm)
          See viewtopic.php?f=20&t=6254&st=0&sk=t&sd=a&start=20# p99144 for pics.
            Originally posted by switched
            After Lift:
            FD: 810mm (= +70mm)
            FP: 807mm (= +69mm)
            RD: 825mm (= +50mm)
            RP: 827mm (= +52mm)
            Gotta be happy with that. From memory you and your brother where doing the install. All went smooth?
            [COLOR=#000080]Nick[/COLOR]
              No problems whatsoever (besides Pedders who changed over the top cap of the new struts). I went solo on this install as I booked in my brother thinking he was off but not realizing he had started his new job (inbetween leaving his old job and starting his new). I couldn't organize to do it on a weekend at this stage so just went for it.
              I put some pics in the Bilstein /Kings thread here:
                FD: 740mm
                FP: 738mm
                RD: 775mm
                RP: 775mm
                After Lift:
                FD: 810mm (= +70mm)
                FP: 807mm (= +69mm)
                RD: 825mm (= +50mm)
                RP: 827mm (= +52mm)
                After a couple of days now, the suspension has settled somewhat. Checking now, I have:
                After Lift:
                FD: 793 mm (= +53mm)
                FP: 800 mm (= +62mm)
                RD: 832 mm (= +57mm)
                RP: 830 mm (= +55mm)
                  Components:
                  OME Nitrocharger Sports upgrade: 9000 struts with 885 springs in the front, 6005 shocks and 896 springs in the rear.
                  Measurements:
                  Before
                  Front Left: 720mm
                  Front Right: 730mm
                  Rear Left: 750mm
                  Rear Right: 750mm
                  After
                  Front Left: 795mm
                  Front Right: 800mm
                  Rear Left: 825mm
                  Rear Right: 830mm
                  2014 Toyota Prado 150 D4D Auto (facelift); ARB Deluxe Bullbar; OME 2" Lift; Rhino Pioneer Platform Rack; Redarc BCDC 1225 with Optima Yellow Top; BF Goodrich Mud Terrain KM2; Lightforce Genuine Custom 70w HID; GME UHF; Safari Snorkel; Rigid Industry SR-Q2 side lights (yet to be installed); Domin8or winch (yet to be installed)
                    Front Setup: Kings medium and Bilstein - ARB bar, Dual batt, Bash plate - 805mm
                    Rear Setup Kings medium and Bilstein - Custom Drawers and Fridge Slide + Waeco CF-80, approx 160 ltrs of fuel - 810mm
                    Suspension has done 10,000km so well and truely worn in... I'll be adding 20mm rock crawler spacers to the rear this weekend and looking to place rear shocks with an 80 series LC raised Bilstein (more travel). Bump stops will have to be lowered too and I don't run swaybars
                    Double_D
                    [b]2006 GXL Prado 1GR-FE [/b]- ARB Lockers & Bar, Tigerz11 Winch, snorkle, Custom Bash Gaurd & Steps, AJ4x4 Rear Bar, Spotties, UHF, Dual batt, 33" KM2s, Custom drawers, Ext Icon Coilovers, 4" SRC Shockies, Dobinson 4" Springs, Diff drop, Light Racing UCA's, Ext SS brake lines, Driveshaft spacer, Superior trailing arms, Nitro 4.56 diff gears, DBA Slotted brakes, TRD Supercharger, Bullet Ultimate Exhaust, XEDE Dual map Processor
                      Double_D
                      Just a side note: When front suspension went in a spacer was installed above the strut which gave around 15mm extra - this was done to compensate for the ARB bar etc.
                        Would you not be able to adjust your billies to the top circlip to compensate for the weight of the ARB bar?
                        Also, did Kings previously do a medium grade spring? - as far as I can tell these days they do:
                        - Standard height
                        - Raised
                        - Rasied heavy duty
                          - Standard height
                          - Raised
                          - Rasied heavy duty
                          Madkore,
                          Yes I could have changed the position of the circlip (currently on the lowest) however I didn't want to lose any travel (I have swaybars removed)... plus i've got a bit up my sleeve if I want to add a winch later on.
                          I don't think they did a "medium" sorry....I have the Raised one's.... I did consider the HD springs as i have no swaybars, it may help the body roll to some degree, but it's not too bad.
                          Double_D
                            I am finally going to bite the bullet and up my suspension in the next few weeks.
                            So here are my measurements before:
                            Sovereign alloy bullbar,
                            Front 745mm
                            Rear 760 mm
                            I'll post my new measurements, and maybe a pic when I finally get out the plastic!!
                            Greg Simpson "Simmo"
                            Simmo's Offroad Tours
                            Winery Tours - Scenic 4WD Tours - Camping Adventures
                            Orange NSW
                            [url="http://www.simmosoffroadtours.com"]www.simmosoffroadtours.com[/url]
                            2006 Toyota Prado TD GXL, Dune in colour.
                            Sovereign Bullbar, Hella lights, cargo barrier, Opposite Lock Rackmaster racks, Waeco 60L Fridge, Cooper STT's, Sandrabba Matts, GME TX3400,
                              Wouldn't you know it....Tough Dog sent up the wrong front struts (HiLux struts), so my baby is spending a night at Opposite Lock tonight until the correct struts arrive tomorrow. Damn :evil:
                              Orange NSW
                                Our prado standard suspension with accessories. FR 735mm, FL 730mm, RR 765mm, LR 770mm
                                OK had the OME suspension put in today; front 884's with 9000 struts, rear 896's with 6005 and poly air bags
                                Before install: FR 735mm, FL 730mm, RR 765mm, LR 770mm
                                After install with 7psi in bags: FR 795mm, FL 795mm, RR 840mm, LR 840mm
                                Will need to wait for settling period now to see what we end up with.
