Suspension Measurements 2
This is a sticky topic.
  • Finally getting my 2" lift next Wednesday, so thought I would throw in my stock measurements first.
    08 Grande, still has stock suspension with nothing else fitted except an alloy bar.
    Front avg. 730mm
    Rear avg Med setting 770mm
    Rear avg High setting 805mm
    Can't wait to see how it comes out. It's only taken 2 years to get around to it.
    • Just had OME suspension fitted yesterday part nos 883 coils and 90000 struts on the front, 896 coils and 60005 shocks on the rear. No bar (next week if I am lucky and an upgrade to 884 coils) or winch or dual battery in the front. Nearly finished fitting out the back, 2nd battery, fridge, air compressor, installed custom draw setup nearly finished.
      Before
      FL: 745 FR: 750
      RL: 750 RR:760
      After
      FL: 795 FR: 795
      RL: 825 RR:830
      • 765 front & 825 rear that is with 2" tough dogs. Thinking of getting some of AJ's strut spacers to bring the front up some more. I have steel bar, steel cable winch, dual batts, steel bashplates under and soon to be rock sliders and brush bars.
        • So I had a 2" Dobinsons Kit installed yesterday.
          Went from original setup with 220,000 Km's with a ARB Deluxe Winch Bar on front, and nothing in the back.
          FL: 703 FR: 703
          RL: 707 RR: 707
          To having the Dobinsons Kit:
          Front:
          Springs: C59-302
          Shocks: GS59-221
          Rear:
          Springs: C59-325
          Shocks: GS59-701
          FL: 790 FR: 790
          RL: 803 RR: 803
          • Originally posted by jasonh View Post
            FL: 703 FR: 703
            RL: 707 RR: 707
            Front:
            Springs: C59-302
            Shocks: GS59-221
            Rear:
            Springs: C59-325
            Shocks: GS59-701
            FL: 790 FR: 790
            RL: 803 RR: 803
            You got a 4 inch lift for the price of a 2" Looking at the before measurements yours had sagged pretty badly so the upgrade was definitely due.
            • Tough dog shocks
              Ome 885 H/D springs
              Front 760mm
              Rear 840mm
              ARB deluxe bar and 12000lb winch
              I hate the nose dive look
              so I added 40mm spacers raised the front 70mm
              not happy as the front sits high at 830mm
              do tough dog shocks have a lower spring seat than the others?
              • Jeepetr, front is too high without a diff drop. Was thus just installed? If so should drop a little, maybe 10mm but keep an eye on the CV angles and boots for leakage. What is the droop like? Measure this and post up because you don't want to top out the struts.
                • Agreed, front is too high. Droop shouldn't be a problem because it looks like only strut spacers were used. Need to space down the bumpstops though.
                  • Originally posted by rogjil View Post
                    Before
                    FL: 745 FR: 750
                    RL: 750 RR:760
                    After
                    FL: 795 FR: 795
                    RL: 825 RR:830
                    Just back from 3 weeks on Fraser Island. The day before we left had ARB Sahara Bar fitted and the front coils replaced with part no 884. Didnt get a chance to check before we left but it looked very high at the front, but figured it might have been something to do with all the gear in the back, drawer unit full of stuff, 60l fridge, 120 a/hr agm battery, compressor, 50l water tank, full fuel etc. Current measurements with just the drawer carcass and battery in the back maybe 60kgs and just about zero fuel.
                    FL: 805 FR: 805
                    RL: 815 RR:820
                    Still looks down at the back to me, maybe it is just the side steps that give that impression. Also I need to jack it up and check droop as on the bumpy tracks I got the feeling the front needed more down travel. Otherwise happy with the ride and handling of the OME setup.
                    • Hey rogjil,
                      Saggy rear end in the Prado is all too common! The OME rear coils are all a bit on the short side for the rear of the Prado, at only 390mm free height, and the 896's are made a bit stiffer in spring rate to try and get some lift.
                      It certainly looks like from your ride height numbers that the rear is sagging when loaded.
                      If you're going to do regular trips with the rear loaded up, I'd look into getting some airbags, they will keep the car nice and level.
                      Best
                      Mark
                      • Hi Mark
                        Yeah might have to go airbags, ideally want to keep the drawers basically full of stuff, battery, fridge, etc in the back all the time. Makes a day trip up Teewah/Rainbow easy.
                        Cheers Roger
                        • Hey Roger,
                          I keep my fridge and battery and rear false floor etc. in all the time for that same purpose! Throw the rods in and off ya go!
                          Best
                          Mark
                          • Suspension Measurements 2
                            Just thought I'd get the ruler out as I haven't checked for ages.
                            FL 785 FR 785
                            RL 820 RR 815
                            Can't remember last time I checked but I have put an ARB steel bar and winch on the front and the fridge and drawer full of recovery gear live in the boot on the right side
                            Sent from my iPhone using Crapatalk
                            BlakMoth
                            Blake
                              FL 785 FR 785
                              RL 820 RR 815
                              Can't remove last time I checked but I have put an ARB steel bar and winch on the front and the fridge and drawer full of recovery gear live in the boot on the right side
                              Just checked Mine after one trip to the barringtons .
                              FL 750 FR 750
                              Rl 812 RR 812
                              AMTS - what difference in height does your Spacer make ? I've been looking at the non lifted (granted no dual battery , winch , ARB Steel Bar) 150 series and it looks more lifted than my 120 with the Old Man Emu 2" sports lift . intrigued as i'd have though i'd have been higher
                              Nige
                              2011 GXL diesel , ARB Steel winch bar, Runva 11000 winch , 9" hid , 22" light bar , sliders, , Eaton E-locker rear , 2" OME lift, Poly bags , Piranha dual battery , 285*70*17 BFG AT/TA
                              • AJ120 is the one that does the strut spacer. Currently the 6mm version gives an actual lift of ~12mm.
                                But yours has sagged back to factory height at the front. I'm guessing that you have 883 coils at the front? You would need new coils as the spacer alone won't get you the 40mm height increase needed.
