Suspension Measurements 2
This is a sticky topic.
  • Lovells 45mm front and 50mm rear lift - ARB Deluxe winch bar (no winch) & dual batteries. No old measurments
    Front 785mm
    Rear 830mm (pretty much empty)
    As it sits now, the rear sits about 10mm higher than the front (measurements from chassis to ground) With a full tank and a load in the rear it sits nice and level.
    I am a bit concerned after reading the previous measurements provided by others varying between 790mm & 810mm up front, that I can't help but feel short changed. Oh well s**t happens
    Luxxxy
    Cheers Skye
    • Having fitted the Bash Plate and ARB Bullbar I have retaken the suspension figures:
      Front Left was 735 mm, now 720 mm
      Front Right was 730 mm, now 720 mm
      Rear Left was 770 mm, now 765 mm
      Rear Right was 770 mm, now 765 mm
      So, lost 10 - 15 mm on the front and 5 mm on the rear.
      Previous figures were with Dual Battery and DIY Drawers. Both with approx 50 litres of fuel.
      • I threw in my old ridepro rear springs into my mates GXL today and we got 840mm straight up. Shall see how it goes once it settles down...
        [CENTER][B][U]Matt
        [/CENTER]
        [SIZE=2]
        [/SIZE][CENTER][SIZE=2]
        [/SIZE][/CENTER]
        • mine is now sitting on
          824mm both front
          825mm rear..cheers
          joey
          -issue 52 Modified 4wds .
          • nice heights there joey, send us a shot of the front cv angles, should be on the limit. cheers samo
            • Originally posted by joey View Post
              824mm both front
              825mm rear
              Is the front sitting higher than the rear now?
              Cheers Skye
              • I would be a bit concerned about 824 in the front. It might also look unusual too as isn't there meant to be about a 20mm height difference from front to back?
                • Just got the Prado back from getting the OME suspension fitted. 90000 Struts and 2884 Coils up front and 60004 Shocks and 2895 Coils in the rear.
                  Before (720 mm Front, 760 mm Rear)
                  After (800 mm Front, 810 mm Rear)
                  • geez trekrider it came up 80mm in the front, must have been as low as my vt commordore, good to see a little lift under the old girl. cheers samo
                    • I was surprised how much it came up Samo. OME said 25mm from Standard - I thought it was low but not that low.
                      • Originally posted by Trekrider View Post
                        Standard is about 750mm front and around 780mm rear. You got yourself the full 50mm or 2inch lift at the front and at least 30mm at the rear.
                        • Hey Dere,
                          I just had a TJM XGS gold suspension fitted to the 120.
                          Also had Polyaire bags fitted to the rear
                          I have a steel bull-bar (no winch) with dual batteries & compressor.
                          All measurements taken with full tanks (180l)
                          Before
                          FL=723mm FR=725mm
                          RL=755mm RR=755mm
                          After
                          FL=775mm FR=775mm
                          RL=810mm RR=810mm (with10psi in polyaires)
                          My departure angle wont rip anymore bumpers!!
                          Cheers .. Dennis
                          Dennis
                          Ag Nomad
                          • tweaked the prado today.
                            front sits at 835mm
                            (895mm-900mm at full droop)
                            2 deg castor RHS
                            3 deg castor LHS
                            rear sits at 865mm
                            everything is maxed out.
                            SIK-120
                            2008 Toyota Prado 120
                            • Originally posted by 8608 View Post
                              front sits at 835mm
                              2 deg castor RHS
                              3 deg castor LHS
                              rear sits at 865mm
                              Mate that's tall!
                              C'mon share - how'd you achieve these heights? Im assuming spacers and diff drop up front and big spacers in the back...
                              Looking forward to seeing some action shots Mate.
                              Micheal
                              Micheal.
                              • Just fitted Tough Dog Lift to my Grande
                                Before Front 735 Now 790
                                Before Rear 790 Now 825 (OEM airbags raised by packing sensor mounts)
                                Marc
