Suspension Measurements 2
This is a sticky topic.
  • #46
    Originally posted by blkmav90
    After OME fitting, winch bar, no winch or dual battery and full tanks
    Front N140S/OME884
    Rear N141/OME895
    Driver
    F 825
    R 795
    Passgr
    F 815
    R 785
    got any pic's.
    not happy with my height at front, after settling.
    • #47
      have done 25000km on the ironman suspension now, and the measurements r front 795mm
      rear 830mm
      with 130ltrs of diesel, its settled a bit but im really happy. cheers samo
      • #48
        Driver
        F 825
        R 795
        Passgr
        F 815
        R 785
        Typo or is the front higher than the rear?
        Mick
        • #49
          Bugger, yes a typo ops:
          Pssgr - Rear 815 Front 785
          Driver - Rear 825 Front 795
          • #50
            sweet.
            i get to do another lift in a few weeks
            • #51
              please explain
              • #52
                Originally posted by samo
                please explain
                i need to fit the spacers that i had turned up, to increase lift with the raised springs
                • #53
                  ah yes that paints a clearer picture
                  • #54
                    I have been going through some old paper work and found the fitting sheet from when I had the OME's fitted.
                    Prior to fitting with ARB Steel B/Bar, Dual Batteries, ARB Roof Rack and Rear Drawers.
                    Front L/R 735/737
                    Rear L/R 755/758
                    Front Springs 885 with N140S
                    Rear Spings 896 with N142
                    Front L/R 795/790
                    Rear L/R 830/835
                    This was done when the car had 2681 km on the clock.
                    I have now done just over 30k km and the fronts are the same and the rears with 8 psi in the polyairs, are 825.
                    I am very happy with the performance of the OME suspension to date.
                    Kevin
                    My Rig Buildup [url]http://www.pradopoint.com/viewtopic.php?f=38&t=4918[/url]
                    • #55
                      Before:
                      Front: 747mm/748mm
                      (with only dual batteries)
                      Rear: 765mm/765mm
                      (Low fuel (light on)/Milford barrier/empty Outback Drawers)
                      Now: (20k old OME springs and shocks plus recent mods. See:
                      http://www.pradopoint.com/viewtopic.php?t=3730
                      Front: 812mm/815mm
                      (ARB steel bar/9k winch/lights/compressor/dual batteries/TJM steel bash plate)
                      Rear: 840mm/845mm
                      (135lts fuel/Milford barrier/drawers/full recovery kit/Fridge slide/large first aid kit/ few spares and tire repair kit)
                      Approx 2400kg on weigh bridge.
                      So call it 2.5" of lift at the front and 3" at the rear.
                      Mick
                      • #56
                        Hello brothers in mud!
                        Got a stock Prado -05 auto. with diesel, dual batteries and a small steelbar with three extra drivinglights (Hella chromium) on.
                        It has ran about 148 000 k´s
                        Front left 730 mm
                        Front right 735 mm
                        Rear left 785 mm
                        Rear right 775 mm
                        And the lowest point under the engineregion is 180 mm´s!!!
                        Pain is just weekness leaving the body
                        • #57
                          Front left 730 mm
                          Front right 735 mm
                          Rear left 785 mm
                          Rear right 775 mm
                          Time for some lift my friend.... or maybe start a "How low can you go " thread.... :lol: :lol:
                          • #58
                            Standard Front 750
                            Standard Rear 770
                            After OME + Steel ARB Bar + Dual Bat's + Spots + Outback Drawers + Recovery gear + 90 l fuel
                            Front (OME884/N140S) 800 settled to 780 after 6000km
                            Rear (OME896/N142) 820 and now 830 (work that out!? maybe 40-50 l less fuel)
                            Very impressive ride with full load , though I have still to come to grips with best way to handle corrugations - just don't like 'em!
                            Ex 1988 Mitsubishi Pajero V6
                            Ex 1986 Suzuki Sierra
                            • #59
                              :shock: who does?? :lol:
                              Air down...slow down... clench teeth...
                              Mick
                              • #60
                                my fronts are 810
                                rear is 830
                                joey
                                -issue 52 Modified 4wds .
