ironman lift kits
  • #61
    Re: ironman lift kits
    Originally posted by Shane & Jodie Ray
    hi all, just wondering if anyone has fitted foam cell in the front and gas in the rear just wondering if it makes a difference to the handling
    my lift kit arrived today and it was not until I got home and found the front struts are foam cell not gas as I ordered
    IF your not planning on doing to many corrugated roads, or outback travel on rough roads at speed, they should be ok.
    Foam cells are good for steering dampers that run horizontal, for the gas to stay in the foam, and are cheaper to make [thats why a damper is cheaper than a shock] and if they get hot, the foam lets go, and gets stuck in the valving, and they dont recover.
    • #62
      good to know.
      guess if this happens, warranty will cover replacements
      [url=http://www.fuelly.com/driver/damonat/prado][img]http://www.fuelly.com/smallsig-metric/50578.png[/img][/url]
      • #63
        Got time and installed the kit today got to book a wheel alignment next week then off to the tyre shop.
        thanks every one for their input
        Dec 2008 Charcoal GXL D4D, 6 Speed manual, Safari Snorkel, ARB Deluxe Winch Bar, Black Duck Seat Covers, IPF800Xs Hid Lights,Toyota Tow Bar, Ironman 8000lbs winch, Sand grabbers, GMETX3440 UHF, Waeco 60lt fridge, ROLA Roof rails fitted rhino roof basket, high lift jack mounts and shovel holder, Ironman 2 inch constant load lift kit
        • #64
          Hey guys, have had my ironman suspension in for about 1.5 years/40000 km and it has developed a squawk in the front end. Put it up on the hoist at work this arvo and discovered that the lower bush in both struts are totally shagged. I've caught it just in time before the metal tube starts to rub on the strut itself. Just looked at the warranty on them and Bugger, just out. Would have had to send them back to Perth where I bought them from anyway and as its our only car that would have been a real pain, so I'll just have to get some new bushes and get them fitted locally. Hopefully better quality ones! Other than that, have found them to be OK. Haven't noticed any sag since fitting them. Did the CSR last year and had no probs
          Travelling Panelbeater
          • #65
            Mine have done about 15,000km and the bushes have also let go in the front. Dissapointing to say the least.
            • #66
              Same problem here, however when I rang Ironman to get replacement, even though I didn't have reciept and it has been over two years they sent me two, via courier, free of charge. That's pretty good of them although they probably shouldn't have worn that much. You may be better of with better quality ones.
              2004 prado GX 3.0 TD.
              • #67
                good to know.
                Uhm,. no,
                warranty wont cover overheating, only faulty materials or workmanship.,......
                • #68
                  Originally posted by samo
                  hey shane and jodie i have the foamcells in the front and nitrogas in the rear, it handles really good, mind you my springs (constant load) are 3 years old and have done 70k, i also have fitted bar ,winch and dual batteries, i also have the 15mm spacer in the front and last time i measure the height was at 810mm, which still gave me 55m droop in the front, rear is still at 830mm, handling wise i think the foamcells make a big improvement, it doesnt pitch up as much as with the nitrogas when i hit a large bump, more controlled and not has harsh. cheers samo
                  FYI:
                  Fusion automotive in Perth offers the Iron man kit for the Prado120 at $775 incl. shipping.
                  http://www.fusionautomotive.com/brands/IRONMAN-4X4.html
                  Just ordered one more than $100 cheaper than from the Sydney outlet (same kit).
                  Not affiliated, related etc. etc. bla, bla
                  • #69
                    Originally posted by chester
                    Ummm dealt with the direct here in VIC completly opposite experience to the one above nothing but helpful
                    same , im in vic and had them within days , had them fitted so far so good ,
                    so much better and half the price of ome and double the lift :mrgreen:
                    Marty gx Prado 05 manual diesel, a/c , abs
                    • #70
                      I'm thinking of putting the Ironman lift in my 1kz diesel. Only have the sovereign bar, but intend to add a winch and dual batteries later this year, so can live with a hard ride for the time being. I do a fair bit of dirt road touring so won't be fitting foam cell shocks. I'll put in the Gas ones.
                      Out of curiosity, if the bushes appear to be failing, should I buy better bushes in the first instance and install them? I'm thinking something like Pedders Urethane ones? Anyone know if they'll fit?
                      Ian.
                      • #71
                        I have priced a constant load foam cell 41mm kit installed from Ironman Kewdale yesterday. Fully fitted is $1362 including wheel alignment as compared to $1012 for the kit alone by itself.
                        Tech day anyone! I need help to fit as I dont have the gear... hahah.. beers could be on me for sure if someone willing
                        • #72
                          To be honest, that doesn't seem like a bad price for fitting to me... An alignment is what, $40-$60? Most workshops are $100p/h... plus the insurance you have that it has to be done properly.
                          (however for that price supply only, I would look at this, free shipping too http://www.4x4suspensions.com.au/pro...oducts_id=6682 )
                          More to come!
                          • #73
                            How is your EFS going Timmy, any reviews on it ?
                            • #74
                              No complaints from me.
                              Much better ride than what was there before... (the 7 year old original stuff) EFS gear comes with a good warranty, which is what got it over the line for me.
                              Nice and firm, but not rough. The car used to float around like a boat and had far too much body roll before, all that is gone now though.
                              More to come!
                              • #75
                                Ian.
                                Don't let the bush issue deter you. I had exactly the same thing with another brand of strut. Keep an eye on it and if it looks a little worse for wear after a few thou then call them up and get a new pair sent to your door for install later on...
                                Speak to Chippy for more info as I know he has just fitted a couple of these IRONMAN kits....
