show us ya flex photos
  • I think there's a 120 in this photo somewhere..?
    Sorry, I couldn't resist showing off the 90's flex You can thank Samo for taking the photo haha
    • what sort of suspension are you running mate cool rig
      • This is what happens when "you wont" comes over the UHF
        2006 GXL 1KZ TD Manual
ID:	641701Click image for larger version
ID:	641701 out at narrabeen
          2004 Manual Turbo diesel 1KZ-TE , 5" lift , 37x12.5 BF Goodrich KM2
          • Another XROX joins the fold
            • Originally posted by Ghostriderhusky View Post
              [ATTACH=CONFIG]8793[/ATTACH][ATTACH=CONFIG]8793[/ATTACH] out at narrabeen
              Oh my.... another Flinders !!! woot
              • This 120 is set up quite nicely:
                • Originally posted by glen_ep View Post
                  Nice one Glen, do you happen to know what size tyres he's running?
                  • Originally posted by Peterpilot View Post
                    275/70R17 with offset rims. I think zero offset
                    • Finally, I have something to show. Not as big as some, but suits me.
                      Just a quick stop on the way home form work, two days after the install.
                      Rear wheel still on the ground, impressed much??
                      Tucked nicely.
                      • And more..
                        • Originally posted by MDSimpson View Post
                          I see you have some extended sway bar links, that helps to get the most out of your shock down travel
                          • Thanks PP. it does help. When I looked at them out if the box, they were the same size, with the bushing set higher up the pin.
                            Towed the camper today, 2hour drive from home, pumped the poly airs up to 30, before packing, I think I need a bigger jockey wheel, but once done had to lower them to about 15psi, to get level.
                            Magic I tell ya, magic....
ID:	643769Click image for larger version
ID:	643769 no sway bars front or rear - 2" old man emu lift
                              • my best flex so far, small bog hole near Yanakie, Vic
                                D4D 09 OME Suspension/ARB Winchbar/Safari Snorkel/IPF Spotties/Cooper ST Maxx Tyres/9000LB Tigerz11 Winch with Dynema Rope/GME Remote head UHF/Sheepskin Seat Covers.....Next on list Dual Battery Sys...In Dash GPS...Rear Diff Lock
