Hi guys and gals.
Long time lurker, first time poster. Plenty of info here. Thanks to every one.
Anyway here goes. I did lots of research before I purchased my lift kit. I decided on the KYB S4 front struts because of there long travel and their trade price was excellent. Also I opted for new upper strut plates as mine had done 170,000km. What I did notice is that the after market struts (roadsafe) lowered the strut 20mm or so due to there being no raised centre section.
So I fitted king spring HD springs to the front and ride height has settled at 807mm. Measured from bottom of rim to guard. 578mm from centre of hub. Droop measures at 900mm exactly on both sides measured the same way. About 93mm of down travel. HOWEVER the cv joints bind at about 3 points. Not so much that you can't spin the wheel, but it does have noticeable resistance. I thought a diff drop kit would help as I was VERY happy with that much droop. However the diff still moves slightly under pressure from the cvs. However it doesn't move much at all.
So, having only recently purchased the car, is the problem that it has had aftermarket driveshafts fitted? Will genuine help? Or is this much droop? Should I fit factory style strut tops to rectify? The shafts seem genuine looking at photos. Boots seem the same etc.. Should I just leave it and enjoy the extra droop, or will it likely damage the cv when I lift a wheel off road (it has traction control).
Thanks in advance
Jack
Thanks in advance
Jack
Whitey
