Hi All. I own a UK spec LC120 LC5 (Grande). The adjustable rear suspension all operates as it should Increasing around 30mm between each settings. However I went out at the weekend and measured it all as I have never been truly happy with its normal operating height as I feel the rake from rear to front is too great.
So on normal setting the rear sits nearly 80mm higher than the front and when switched to high increases to 110mm difference. Reading on this forum the difference typically on a standard car is around 30mm higher at the rear from what I have read.
My questions is how do I lower the normal height by 50mm at the rear. Is this something that can be done via techstream and DIY or is it Toyota dealership modification only
Any help appreciated.
P.S. Great forum .
P.S. Great forum .
