OEM droop on factory 120 coils
  • OEM droop on factory 120 coils
    Hey all,
    Could anyone who measured droop on their factory coils on their 120 please post up some figures?
    I'd also like to see the original ride height measurements as well, so typical bottom rim to guard for ride height and bottom rim to guard at full droop.
    Thanks everyone!
    Best
    Mark
    When people quote maintaining 60mm droop, they are talking about droop at the wheel?
      Yep, so bottom of rim to arch with wheels off the ground minus bottom of rim to arch with wheels on the ground equals droop.
      Matt
      Sent from my SM-J110F using Tapatalk
      Rig build here
        Hey,
        See the photo in this thread for how to measure your droop;
        http://www.pradopoint.com/showthread...Measurements-2
        Best
        Mark
          ...bump...
          Anyone out there still driving their 120 on factory coils who can measure their droop??
          Best
          Mark
            I hope this is of some assistance with your data gathering. No rear coils, but the max down travel depends on shock length anyway until about 615mm, then the swaybars bind.
            These measurements were taken with original suspension and TEMS shocks, which have the same extended length as Toyota OEM shocks of 575mm:
            Originally posted by Peterpilot View Post
            Just finished some suspension work recently where the aim was to achieve a 50mm lift and retain a comfortable ride.
            At the front I fitted Lovells 64610087F front struts and OME 883 springs with a 10mm collar under the spring seat (same setup as the Ironman struts).
            At the rear I fitted Lovells 64612489 rear shocks with 7mm spacers on the sway bar mounts. The rear air springs were raised with 14mm spacers under the height sensor brackets.
            Front
            735mm static before, 800mm after
            845mm maximum extension before, 890mm after
            110mm downward travel before, 90mm after
            Rear
            780mm static before, 825mm after
            745mm Lo before, 790mm after
            815mm Hi before, 860mm after
            880mm maximum extension before, 930mm after
            100mm downward travel @ Normal before, 105mm after
            65mm downward travel @ Hi before, 70mm after
            Happy with the result for now, rides more comfortably than before and also handles better.
              Hey Peter,
              Thanks for that info!
              It's been a while, good to see you back posting!!
              Best
              Mark
                Hey Peterpilot! Good to see your post!
                Sent from my iPhone thingy
                  Hi Peter,
                  Been waiting for the Grande owner's reunion party. Thanks for showing up!
                    Originally posted by Whitey View Post
                    ...bump...
                    Best
                    Mark
                    Grande measurements are here
                    http://www.pradopoint.com/showthread...l=1#post217049
                      Hi Craig, your black beast is looking good as always.
                      Hi Peter,
                      My pleasure, Andrew.
                      845mm max extension on standard 540mm TEMS struts from back in 2009, same as mine was in 2012!
                      Surely there are others that measured their suspension before turfing out the standard shocks?
                        Hey all,
                        After getting a few different figures for OEM droop, the average is around 95mm.
                        Below is a plot showing strut length vs bottom rim to guard for a few different setups.
                        You can get the droop by taking the difference of the limits on the x-axis, eg., 845-750 = 95mm for the red line, which is the OEM geometry. You can also get the amount of strut travel from the limits on the y-axis.
                        There is quite a big difference in what the strut length is at ride height, which will depend on the coil rate, coil free length, and the coil seat position.
                        Best
                        Mark
                        Whitey
                        Shockie Maker of the Month Award
