Hi I attempt to fit my rear suspension today but realize it does not include the top bushes.
Would you reuse the OEM bushes? I check and see that the
OEM bushes would not fit the new suspension as the hole on it is not really circle. I would have to drill a hole
Where can I buy the bushes/washers? I was looking in my local SuperCheap store but could not find any!
I actually found the part from Nolathane http://www.nolathane.com.au/product_...t_number=43113 but it's pretty expensive. Not sure if there is any cheaper alternatives
photoprado
. Then somehow I decided to go for a test drive hopefully the airbag height sensor would adjust correctly. Unfortunately my left airbag pop out as I obviously forgot to check to make sure the top mount was in correct position. Both my bags didn't have the upper retaining clips >.< and I didn't even think about positioning the top mount as I focused on installing amts's spacers
