Simply ask your seller if they are legal in Australia and comply with ADR's. If he says yes, Push for it in writing.. As it is not legal and is against ADR's in this country. Also ask him about what happens if you bottom out in a hi speed rut or washaway? As the bump stops are now useless so won't stop your shocks from taking the load.. Meaning bent or snapped components.. These are the questions you need to ask..
Abusing the knowledgeable suspension guys here won't get you anywhere.. Its obvious you're trying to justify what is a poor purchase and will likely end up costing you in the long run, so best of luck with that.
