Front sway bar links
  • Front sway bar links
    So a quick check under the front end this evening, before we head away for the weekend, has revealed 2 deteriorated sway bar links.
    Any tips and tricks on where to buy from, which brand, what I should check/replace whilst I'm going to the trouble???
    Ok, I'll elaborate.
    Should I replace all of the bushes and the ball joint, and test the springs/shocks, because they're all likely to be on the way out too?
    Or is replacing the sway bar links as simple job to keep me on the road?
    I've got 130,000 km on the clock.
