drivers side steering knuckle
  • drivers side steering knuckle
    hey gurus,
    my wife crashed our 2007 120 series and bent the drivers side steering knuckle. Ive found one on ebay but its for a 2003-2006 120 series. It looks the same so i'm wondering if it will fit. The guy said he doesn't know. Can someone enlighten me
    Yep it'll fit. The only difference between years it if they have ABS or not.
    http://www.japan-parts.eu/toyota/gr/...-knuckle#43211
      Thanks mate your a legend
        Is the ABS sensor drilled and tapped into the hub?
        Better check if your old hub differs from a non ABS one.
        On my 90, knuckle had a casting lump for ABS. On non ABS, it was just a lump, on ABS it was drilled and tapped for the sensor.
        That was the only difference between the two hubs.
        Inside of course the ABS unit had a notched Hall effect wheel whereas non ABS just had a spacer ring.
