Hi All,
I have a 2007 D4d Grande and have just replace the airbags with new ones from airbag man. My problem is that the compressor isn't pumping them up.
I have applied power directly to the compressor and it runs so thats not the issue. The H-N-L lights all show when the ignition is turned on the Im left with only the N light and the ride height switch won't change the position, I've checked all the fuses/ relays and there's nothing there either.
Im stumped as to what might be causing the problem.
Thanks!
NHG
Thanks!
NHG
