Hello everyone. I noticed when under the car that there is grease leaking from the bottom of the left LCA ball joint boot. Just wondering the urgency to get it fixed as I can't get it done straight away and need to do a 2K run next week . I cant locate a split yet but as it appears to be coming from the bottom I assume no dirt & moisture is getting in.
Lower control arm ball joint leaking Grease
I just pulled out both LCAs and had a look at the ball joints. Didn't seem to have play after 300k km. It is a bit looser than the new ones.
I bought this set to remove the ball joints.
https://www.ebay.com.au/itm/203507216455
The one on the top left worked.
