Hi,
Has anyone had some experience with the effect if any on ride comfort when LT tyres have been fitted and is it possible to convey that in "it rides like there is 45 psi" or something of that nature.
Secondly what sort of minimum pressures can you run on 265/65/17 LTs.
I normally run 30 psi in city with no load in the Prado and that gives me the 4-5 psi increase when hot and I have very even tyre wear.
With a full trip load and the OME suspension it rides as smooth as a standard suspension Prado and I was a bit concerned that the LT tyres might make the ride a bit harsh.
thank you in advance for any info
Max
Max
