Wheel size and offset questions
    [quote="Brett"]I think you will find that the Qld Transport reg is for no larger than 15mm in rolling circumference,
    Typo: Rolling circumference of 15mm would only be about 4.7mm increase in diameter, so should be 15mm diameter :?
    06 GXL D4D, 6spd, Snorkel, ARB bar, XS900 50w HID lights, 55W HID Headlight upgrades, T/bar, 7" GPS, QStarz data logger, 52L Bushman Fridge, Premier winch, Sandgrabbas, GME TX3440, AE4705 antenna, Scangauge II, Dual Batteries, Aero bars & rack, Drawers, 2" Ironman/Rancho/King lift, Under bonnet compressor, Black ducks, Voltage booster, Rear table, AVE TPMS,
      Originally posted by way/bel
      A,p50 offset wheel would move the the wheel in closer to the susp, A 0 offset or neg offset would be better to move the tyre out, would be better.
      way/bel is correct in what he say's about wheel offset, never heard of anyone using +50mm offset, not many even have +30mm as standard, current Hilux does.
