Staun Bead Locks
  • Staun Bead Locks
    Hi all,
    Has anyone installed the Staun bead locks? If so what are your thoughts on them? They look to be a great idea for stopping the tyres coming off at low PSI. I noticed that they were already on ebay and was thinking about getting a set.
    http://cgi.ebay.com.au/4WD-Staun-Int...QQcmdZViewItem
    Roll on the 2010 Pradopoint GTG
    Pradopoint GTG website:
    [url="http://www.pradopointgtg.com"]http://www.pradopointgtg.com[/url] (final website location on its own domain)
    My Weather Station In Alice
    [url="http://www.alicespringsweather.a60.us/"]http://www.alicespringsweather.a60.us/[/url]
    My photo website:
    [url="http://centralian.redbubble.com/"]http://centralian.redbubble.com/[/url]
    They are illegal for road driving mav. You don't really need them in sand.
    More for comps and stuff... The cheap way of doing similar stuff is to use
    good quality tubes in tubeless tyres (mainly for mud/rock stuff not for sand). Won't be able to go to 2psi with tubes but 10 psi would be ok for the mud.
    [color=blue][url=http://www.pradopoint.com/showthread.php?12128-2004-120-GXL-V6-Petrol-Buildup-*Warning-Picture-Heavy!*&highlight=picture+heavy][b]My Prado Buildiup Since 2004[/b][/url][/color]
    [b]2004 120 GXL V6 4sp Auto D694 LTs and MTRs with Kevlar (best of both worlds )[/b]
    [url=http://www.fuelly.com/driver/lc120man/prado][img]http://www.fuelly.com/smallsig-metric/48063.png[/img][/url]
      Do tell why...
        Do tell why...
        Cause ths is what I been told a whle ago .
        However just double checked agan and looks like Staun ones are legal ops:. But almost all mechanical/external ones are not legal..
          [quote=lc120_man]
          Do tell why...
          However just double checked agan and looks like Staun ones are legal ops:. But almost all mechanical/external ones are not legal..[/quote:1rl3hln7]
          Correct internal legal* external illegal
          * the act of drilling the 2nd valve hole in the rim does technically make the rim unroadworthy...
          A friend has them, good for not losing a tyre off the rim but you still get crap in the bead which causes leaks, not a 100% solution
            I know this is an old thread, but just to clarify for external bead locks (in Qld anayway) You need to check what markings are on the bead lockers. If they have markings on them similar to: 6J, 7J or a stamp from the manufacturer then they can be used on the road as long as then don’t protrude or the possibility of them coming loose. If they have no markings or manufactures stamp then they are illegal for road use.
            Black 2008 D4D GX, Bolle tint, Airtec snorkel, Hayman Reese tow bar, Staun deflators, ARB Air, front & rear extended diff breathers, Milford cargo barrier, Poly Air, 2" lift, XGS suspension, road tyres - 265/65x17 Grandtreks, play tyres - 265/70x17 Wrangler MTR's, ARB Sahara Bar, TMax 9000 winch, custom winch panel, Uniden UHF, Garmin 76csx with RAM mount, Eee PC with OZI, triple IPF 900XS spotties, rear ARB diff locker, Brown Davis underbody protection, Darren McRAE Auto Craft Rock Sliders
              In SA the act of drilling the 2nd hole in the rim makes them unroadworthy, you'd be unlucky to be caught out though...most coppers wouldn't notice the second valve at a glance
              May be a good option for a second set of steelies with some aggressive muddies on.
              Still a bit of overkill on a car like the Prado, not exactly a hardcore rock crawler.
              1. tyres... 2. lift.... 3. diff lock... You'd be surprised how capable the Prado is with these mods. Next step would be to buy a dedicated rock crawler
              Mick
