BRIDGESTONE D694 PRICE
  • Run them all at the pressure the tyre shop told, i run mine at 36 psi. The tyre placard gives u a pressure set for comfort.
    [b]Rob[/b]
      I have D694LTs in a 265/70/R16 size on my 90 series Prado and the tyre place said to run them at 38PSI on bitumen and 36PSI off-road. That seemed a lot to me as the owner's manual said to run my factory GrandTreks at 26PSI. The only difference is the D694s are an LT spec tyre and the Grandtreks were HTs. I still have a GrandTrek as a spare so I'm wondering if this pressure differential will be an issue should I need to use it.
      In case anybody is wondering about price still, I paid $265 each fitted and balanced in March 2011.
      If you pump the spare up to the normal tyre pressure run by the rest of your tyres, then you will be OK. If its already under inflated - then inflate the sucker....nothing worse than running different pressures should you get a flat tyre. It will only cause you headaches.
      SSSHHHH be very very quiet were huntin wabbits.
      • Now we all do. Thanks
        • Originally posted by D4D-GXL View Post
          Huh? I'm confused :-)
          BTW, my spare is 8 years old and has never been used to my knowledge, it's stored under a hard cover though. Somewhat OT but on another thread I was advised it is past its use by date and I should get rid of it' would like to know if this is correct advice.
          • paid $251 each here in Adelaide a few weeks ago. LT construction. PM me if you want the details, it was a big franchise, so you should be able to get a deal close to this across Aust. Ran them at 37psi but felt too soft, so upped it to 40psi. Feels better now, will see if it puts economy back to where it was running the previous HT tyres.
            Westy.
            2001 VX 3.4, Dual Fuel, TJM Nudge, IPF Spots, Uniden UHF, Ming Tint, Dust deflector, side steps, Bridgestone D694LTs. [url=http://www.fuelly.com/driver/Westy90/prado][img]http://www.fuelly.com/smallsig-metric/68370.png[/img][/url]
            [url=http://www.postimage.org/][img]http://s1.postimage.org/gu8j7rlw/prado_avatar.jpg[/img][/url][url=http://www.postimage.org/][img]http://s1.postimage.org/guigfukk/08062010_001.jpg[/img][/url]
            • Just been trying to buy a set of 694's in 265/65/17 here in Brisbane and the best price i can get is $315.00 maybe i need a holiday in Adelaide, which dealer did you use,
              Cheers Bribiejohn
              • Try Jax's quickfit maybe at Aspley. Also remember tyres r on special from time to time so some prices would be special price..
                [b]Rob[/b]
                • Hi Hutch, I tried Jax Aspley they wanted $335.00 Jax in Victoria $265.00 Jax Adelaide $259.00.. Hope Brisbane gets some specials soon
                  Cheers.
                  • Originally posted by bribiejohn View Post
                    That price of $265 in Vic was a special, not sure if it's still running. It included fitting and balancing and I think disposal fee for the old tyre when I had mine done.
                    • Rob
                      What pressure do you run in your tyres on the bitumen?
                      Brett
                      2008 GXL Diesel Auto - ARB bar, UHF radio, Airtec Snorkel, custom drawers
                      • 36 Psi I run otherwise to rough, some run 40.
                        [b]Rob[/b]
                        • 36 PSI cold for me too.
                          Snowy
                          • Thank Rob and Snowy. Will try that I think.
                            brett
                            • Latest price in Adelaide 319 rec retail, best price I could get even with Bridgestone's so called sale 305 fitted & balanced
                              Dennis
                              Ag Nomad
                              • Latest price in Brisbane at two different tyre chains, $340 and $350 respectively. I too would appreciate a special on them right about now.
                                Confidence - The feeling before you fully understand the situation
