Finally took the time to set my tyre deflators. I also measured the traction length of my Dunlops (yes when they wear out) as I am planning a Victorian desert trip shortly.
Pressure Traction Length
36 PSI ( Hwy mode) 220mm
28 PSI 235mm
24 PSI 250mm
20 PSI 280mm
17 PSI 290mm
What pressures do you use in the sand (desert sand)?
28 PSI 235mm
24 PSI 250mm
20 PSI 280mm
17 PSI 290mm
