Tyre Traction Length
  • Tyre Traction Length
    Finally took the time to set my tyre deflators. I also measured the traction length of my Dunlops (yes when they wear out) as I am planning a Victorian desert trip shortly.
    Pressure Traction Length
    36 PSI ( Hwy mode) 220mm
    28 PSI 235mm
    24 PSI 250mm
    20 PSI 280mm
    17 PSI 290mm
    What pressures do you use in the sand (desert sand)?
    Re: Tyre Traction Length
    Steveo,
    Did you end up getting an answer for this - did a search and couldn't find a reccomendation on pressures for sand driving.
    matt.
    Big Dog
      BG, you should get by in sand with 15 -18 psi.
      Dustie
      Self confessed PP addict!! hmm.. now thats not a bad habit is it......
        I generally drop to about 16psi and gets me most places in sand. Saying that I have had one ultra soft beach that I had to drop them to about 8psi just to get out.!
        03 Grande V6 4.0L, ARB Deluxe winch bar, XD 9000 Warn winch, Pacemaker Headers, Colour Coded Safari Snorkel, K&N Airfilter, Slotted RDA rotors, 55W HID Hella Rallye 4000 spotlights, Dual batt, TJM comp, TJM underbelly bashplate and custom stainless front bashplates, Extended diff breathers, Reverse camera (Eclipse), Yokohama AT-S, ICON 2.5 adjustable remote resi coilovers(front) ICON 2.5 piggyback shocks(rear), 2" lift airbags, Icom ic400pro, Engel 40L, Custom drawer system, Stainless recovery points, Kimberley MyCube rooftop camper.
