Wow. I didn't expect such a detailed reply. Thats a great explanation and clears a few things up for me. So its the friction between the two plates that stops things moving not just the bolts. That makes sense.
Recovery Points
Originally posted by fido666 View PostHi David,
I have the same hydraulic lines as in your 2nd photo and yes the chassis hole is behind that. I'm not 100% sure how the fitter got the nut plate in there but will try and confirm. I notice there is another hole in the chassis on the other side of the strut but I'm not sure if the Roadsafe nut plate will have a long enough wire to reach far enough forward from there. I'll post back once I've spoken to the shop that did the fitting.
Corine
I ended up just going ahead and purchasing a set from Everything 4WD. They're the modified design like yours, so a bit lower rating but I have flexibility to fit a TJM bullbar later now if I choose to without having to take to my recovery points with the angle grinder!
Thanks for the offer to talk to your fitting shop, but I had a fiddle tonight and getting the nut plate through that hole behind the hydraulic lines is not a problem. It's a bit more fiddly than the RHS but just requires a little more careful bending of the wire.
Tomorrow night I'll drill the top holes out a tad to 13mm to enable the bolts to pass through (as Mike did above), then after a couple of coats of red oxide on the holes and I should be ready to just bolt the points on!
David.[SIZE=2][U]2012 150 Series D4D Kakadu[/U][/SIZE]
[SIZE=1]Wynnum Towbar, Narva Merit/USB/lighter sockets, Pirahna dual battery tray, Redarc BCDC1240, Xantrex LinkPro battery monitor, 600W inverter, ARB onboard air & WaterWatch on AMTS bracket, Phillips 35W HID high beams, UHF, Roadsafe front recovery points, Offroad Systems drawers with integrated water storage with tap concealed in rear tailgate, ARB 47L fridge.[/SIZE]
Originally posted by D4DDave View PostThanks for the offer to talk to your fitting shop, but I had a fiddle tonight and getting the nut plate through that hole behind the hydraulic lines is not a problem. It's a bit more fiddly than the RHS but just requires a little more careful bending of the wire.
Corine,
I haven't mounted the points yet, so can take a pic tonight, but the size of the plates on the nuts was fine. Just fits through the hole and then plenty of room to rotate them via the wire and get them into position.
Yes I was surprised by Mike's comments too - my kit came with the 12.9 bolts, flat & spring washers - 4 of each. They actually sent 6 nut plates & as we know the 150 only needs 2, so I'll have some spares...
I mounted my points tonight. Easy to fit, however, my understanding is that the 'bow' of the shackle is meant to run through the eyelet on the recovery point and the strap sit round the pin. The problem I'm having is that due to the proximity of the factory bash plate, there isn't enough room to thread the bow shackle through the point - I can only get the pin through, resulting in the shackle being the other way around.
What have others done about this? Just not worried about it? The equaliser strap is sufficiently long that the strap pulls pretty straight and there is no twisting force on the recovery point by the pin, so it seems reasonably OK, but just interested to check what others have done?
looking for recovery points for 120 with ironman bull barPrado 2008 d4d Auto, Redarc dual battery, 285/70/17 mad hogs, ironman bull bar, Mako TDS 12,000Lb Winch with synthetic rope, MAXTRAX on TraxRax, AJ120 Rock sliders , ironman bashplate, Front and rear ARB air locker,3'LEGENDEX EXHAUST SYSTEM
Originally posted by D4DDave View PostI can only get the pin through, resulting in the shackle being the other way around.
Thanks Corine - fair enough.[SIZE=2][U]2012 150 Series D4D Kakadu[/U][/SIZE]
I know I am resurrecting an old thread however just picked up my recovery points today (may make someone more comfortable if they have to recover me on the GTG). I see Andrew has posted a reference to torque settings, however I am wondering what torque you guys used when tightening the bolts. Given that you cannot get a wrench on to the top nut (it is just welded to a thin piece of plate on the end of a wire) I am not all that sure of the integrity of this setup
Cheers.......WayneWhite 2012 GXL 150 TD Auto. Work in progress. Aiming to spend less than when I kitted out the 120!
Originally posted by hulbyw View PostI know I am resurrecting an old thread however just picked up my recovery points today (may make someone more comfortable if they have to recover me on the GTG). I see Andrew has posted a reference to torque settings, however I am wondering what torque you guys used when tightening the bolts. Given that you cannot get a wrench on to the top nut (it is just welded to a thin piece of plate on the end of a wire) I am not all that sure of the integrity of this setup
Cheers.......Wayne
Thanks Andrew. Supplied bolts are 12.9, 12mm so that would be 130 lubricated (does Loctite count as a lube?). My medium size torque wrench only goes to 110 nm however when I tightened the bolts as tight as I could, the wrench didn't even click. So I reckon they are to FT specs but not as tight as your table says. I have marked the bolt heads with a paint stick so will see how they go. You were quite right about the nuts on the plates. They did stop turning fairly easily
Cheers...WayneWhite 2012 GXL 150 TD Auto. Work in progress. Aiming to spend less than when I kitted out the 120!
