Hi David,
The top mount hole you have marked in the 2nd photo is the one which needs the nut plate behind it. The one at the bottom/forward end of the chassis where the lower bolt would go already has a captive nut behind it welded to the chassis.
I have the same hydraulic lines as in your 2nd photo and yes the chassis hole is behind that. I'm not 100% sure how the fitter got the nut plate in there but will try and confirm. I notice there is another hole in the chassis on the other side of the strut but I'm not sure if the Roadsafe nut plate will have a long enough wire to reach far enough forward from there. I'll post back once I've spoken to the shop that did the fitting.
Corine
Corine
