self fitting a Winch
  • self fitting a Winch
    Hi everyone,
    I'm sure there is a thread link for this but couldn't readily see it so if someone could post it here it would be appreciated.....
    But if not, has anyone fitted a Warn winch (really any winch) to their 150 themselves?
    I have picked up a XD 9000 and want to fit it myself. Though after reading about chassis cracks........ bit late now!!
    Yes, I've fitted an Avenger Mako 9.5 to my ARB Deluxe bar myself. The process was simple enough and can be done with the bar still on the vehicle. You will need to rotate the gear box 90 degrees but that is easy on most winches. Another pair of hands will also make it easier when lining up the bolts.
    Wiring is straight forward and the included wires had just enough length for the job.
    [SIZE=1]2011 Crystal Pearl VX D4D Auto, MT ATZ 4 Rib, Full River 105AH / Redarc SBi12 DBS (TJM Tray), CKMA12 Air Comp, Alpine INA-W910R - PDX-5 - Type-R Speakers, Engel MT60FP, Rhino Alloy Platform, Foxwing Awning, Rear 12V Cig and Engel Socket, ARB Deluxe Combi Bar, Safari Snorkel, LF 240 XGT's + HID Upgrade, HB3 (9005) HID Upgrade, Bilstein / Lovells 2" Lift Suspension, Chip-It, Alpine PKG-RSE2 Roof DVD Monitors, Maxtrax, GME TX3540 + AE409L, Avenger TDS 9.5, ARB UVP, ARB Protection Steps.
    [/SIZE]
      Same here, turned the control box 90 deg, dropped the plate off ARB bar and the winch fitted through the gap.
      If you are worried about the cracked chassis, i'll give you a bad price for it i could do with an upgrade.
      [size=1]2011 GXL D4D Auto | ARB Deluxe winch bar | Bilstein/Ridepro platinum lift | MT ATZ P3's | Dick Cepek Torque rims | Airtec snorkel | Lightforce Genesis 55w HID | GME UHF | 55w HID high beam | Rhino Rack bars & Cage | ISI extreme rack | Dual Optima Batteries | Milford MXV-70 cargo barrier | ARB onboard air | Prodigy P3 | Drawers & Black widow fridge slide | Waeco CF-50 | Kaymar rear bracket and LED light | EscapeGear seat covers | Sandgrabbas and more...[/size]
        Sames as above... Rotate the gearbox! I did mess up and have the rope spooling off of the wrong site of the drum though and it was only as I held it in place I realised. I had to pull it out again and do the rotation thing another 180degs. It is a fairly heavy job and two pairs of hand would have made the lining up a bit easier.
        [SIZE="2"][COLOR="red"]2010 Prado 150 GXL TD[/COLOR] - Previously Darren253
        My Rig Build: [url]http://www.pradopoint.com/showthread.php?17046-Darren-s-GXL-TD-150[/url][/SIZE]
          Thanks everyone. I also have the ARB deluxe so I'm glad i don't have to remove the bar to fit it. MY local ARB rep wanted $350 to fit the winch I felt that was a bit rich!!
          Thanks alternative for the offer but I think I'll take the risk lol.
          I've got a mate whos going to help me fit it so thanks all for the tips it sounds like a fairly painless process,
