towbar tongue
  • towbar tongue
    Hi All
    I have a factory towbar that with the standard tongue has the ball too low for my boat trailer. The issue is i cant get my jockey wheel on my boat trailer up and down without killing myself (getting too old ) My thought was just to turn the tongue upside down and then pull the ball off and re mount on the now "right way up.
    Should be fine i guess? anyone come up with a good reason why i shouldnt do this....?
    cheers
    Sounds like a perfect excuse for a lift
      Or, at the least air bags.......
      [color=#0040FF]Rob[/color]
        Yep, you can just turn the tounge around. It says that it in the fitting instructions for the tow bar.
        [FONT="Georgia"]2012 graphite GXL d4d manual.
        105ah dual battery, redarc dc/dc charger. Maxxis Bighorns 265/70.
        Arb bar. Full length roof basket. 2inch king spring lift. [/FONT]
          Hello Rugbynut,
          Turning the tongue around is fine, carefully check that you can open the rear door with the tongue upside down as I did this to mine and now I cannot open my rear door with the trailer attached. Bit of a pain with boat gear in the truck and the door blocked shut.
          You could shorten the trailer jockey wheel (or buy a shorter one) or fit a 40mm lift to the suspension.
          regards
          Ross
            Originally posted by discoveraus View Post
            Hello Rugbynut,
            regards
            Ross
            Thanks Ross
            I think the lift is a bit of an expensive option
            I think ill just turn the tongue
            Thought about the jokey but its already quite new.
            thanks for the replies guys...
              I have problem fitting my bike rack to the standard tongue , if you are in Brisbane the guys at Wynnum towbars made me a custom tongue for $50.
                Had a read of my towing instruction booklet that comes with the genuine toyota tow kit for the 150.
                It says if the tongue can be inverted that it will have a sticker on it saying the different load ratings for one way vs. the other
                (Mine doesn't have this sticker)
                I am hoping I can still make the change as I would like some extra height as well.
                  My tongue still has the sticker, doesn't say anything about a different rating if it is inverted;
                  WARNING
                  TOYOTA
                  For trailer towing only
                  Tongue part number PZQ63-60160
                  This tongue is to be used only with
                  Towbar part number PZQ64-60160
                  Max towbar capacity 2500kg
                  Max towbar download 250kg
                  [SIZE=1][B][COLOR=#ff0000]2010 Silver GXL Prado T/D Auto.
                  [/COLOR][COLOR=#0000ff]2014 Leisure Matters X-Track Camper Trailer.[/COLOR][/B][/SIZE]
                    Yep can confirm that just read my fitting instructions. Flipped mine over to suit my CT.
                    [COLOR=blue]Current rig - 150 GXL D4D Auto TJM bullbar. Airtec Snorkel. ARB Underbonnet Comp.
                    Previous rig - 02 TD GXL.[/COLOR]
