Install of accessories
  • Install of accessories
    After installing diff breathers from BRC, I went to tackle the install of ARB aircompressor, P3 brake controller and GME 3450, but after pulling the dash apart to find a position, and slots to put the rocker switches in, I realised that the rocker switch doersn't fit in the 150 slots, and it is very hard to find positions for installing other accessories and switches.
    If you have installed spot light switches, UHF or any othe gadget, could you please provide some guidance as to where and how you installed these items. Pictures also would be great. If you had to make the solts bigger for the rocker switches, can you please provide the way you went about it....
    All I can say, is the 150 is very different behind the dash than the 120.....
    Any assistance would be greatly appreciated.
    Hi sapradogxl,
    All you have to do is take a file to the existing blanks on the right hand side.
    Just shave about 1mm and the rocker switches fit. You will not see it either
    Hope this helps.
      Either file out existing or get switch that fits from sidewinder.com.au, which looks better and has a wiring harness that fits more conveniently in the space behind the RHS switches.
      Prado 150 GXL Auto Diesel, Toyota tow bar, rubber mats. RedArc remote head brake controller behind screen. Rhino Rack with Rhino bag, TJM colour coded steel Bull Bar, TJM Sump and transmission bash plates, Airtech snorkel, IPF 2xHID Spot and 2xHID Fog. Home built aluminium framed drawer system, 12 pin plug to van, High current wiring to cargo area, 7.5inch screen for 5 rear vision cameras (4 in van).
        New-Tech have switches available for the 150 that look "factory" good quality.
        Sent from Richos iPhone using Tapatalk
          Heres the link http://www.newpro-tech.com.au/Clights.htm
            Link here http://www.sidewinder.com.au/page108.html
            I'm aiming for these http://otrattw.com/products.php?cat=14
              I don't want to rag on ABR, but DO NOT buy his switches... they're f*cking sh!t to say the least: I bought a number of them and they didn't fit, didn't work, and he didn't care.
              Whether they're the same as newprotech, I don't know...
              2011 150series GXL
                I have two in my 150 they r as sweet as, work and look a treat, I wonder if u got the wrong ones as the 120 ad 150 is different as an example.
                [b]Rob[/b]
                  I hope they realise who they are messing with Wooley!
                  PradoPoint Badass.
                    No they were the right ones, They just didn't fit. The buttons would stick, and the switches came apart anyway.
                    Maybe he has changed suppliers since I got mine. Either way, I wasn't impressed.
                    2011 150series GXL
                      Hmm, maybe I'll stick with the otrattw ones then and do some filing. Needed different etchings anyway for the different functions.
                        Those look seriously cool too.
                        2011 150series GXL
                          Hey AMTS,
                          I finally got around to fitting the switches I picked up from you. No wiring yet because they only have 4 pins instead of the 6 pins that were on another switch I installed for the thermo fan. I'm not sure which pin does what.
                          Do you have a wiring diagram and is it just a given that a relay is to be used.
