ARB Bullbar light smashed
  • ARB Bullbar light smashed
    The round light on my ARB Bullbar has been smashed - maybe by a rock. I could go to ARB tomorrow and get it replaced but first I'd like to check a couple of things with you experts:
    The light looks to have flimsy cheap glass. Is there a better housing to use rather than ARB's?
    Is it easy to replace? I assume I'll have to remove the bash plate to get to it.
    2012 GXL Diesel Auto.
    I looked around for an LED replacement and couldn't find anything that would easily fit, so I just replaced them with the ARB lights. Yes, you will need to remove the wings under the bar to access the lights. I also siliconed up the rubber grommet at the rear of the globe as it leaked water into the lens after a small water crossing.
    VXWesty
    [SIZE=1]2011 Crystal Pearl VX D4D Auto, MT ATZ 4 Rib, Full River 105AH / Redarc SBi12 DBS (TJM Tray), CKMA12 Air Comp, Alpine INA-W910R - PDX-5 - Type-R Speakers, Engel MT60FP, Rhino Alloy Platform, Foxwing Awning, Rear 12V Cig and Engel Socket, ARB Deluxe Combi Bar, Safari Snorkel, LF 240 XGT's + HID Upgrade, HB3 (9005) HID Upgrade, Bilstein / Lovells 2" Lift Suspension, Chip-It, Alpine PKG-RSE2 Roof DVD Monitors, Maxtrax, GME TX3540 + AE409L, Avenger TDS 9.5, ARB UVP, ARB Protection Steps.
    [/SIZE]
      Do you use the fog lights? I don't so I am replacing them with LED daytime running lights from Narva.
        Exactly what I'm considering - and I don't even have the bull bar yet! Let us know how it goes - do you know if they would fit ok?
        Prado 150 D4D AUTO GXL with ARB Deluxe Winchbar, Brains' TG150 Transfer Case Actuator Guard, Bilstein/Ridepro 50mm Lift, Safari Snorkel, D697 265/65/17 LTs, Dual Battery Setup with REDARC Controller, REDARC Tow Pro, Toyota Tow Bar, Maxtrax - towing a Camprite TL8s fitted with GXL wheels and D697s.
          I am also interested as mine cracked going through water. Apparently they dont like the temp drop when on......
            I second that! It's exactly how i cracked both of mine.
            [/SIZE]
              Why would you have them turned on when in the bush?
              This is the Narva DRL (71940) I am planning to fit. Just need to work out how to fab up a bracket for it as it is 90mm whereas my IPF fogs are 110mm.
              D4D
              Addicted PP Member
                D4D did you find any pics of the Narva light lit up? Looks like a good idea. The 71930 has different mounts which may be better for you.
                  No I haven't found any lit up shots although most newer trucks use them so I have an idea what they look like. The existing IPF fog lights have a 4 screw mount like the 79140 so it shouldn't be too hard to retrofit.
                    Thanks for the info guys. I went to ARB and they are quoting around $40 for a replacement light but none in stock for a couple of weeks.
                      Those Narva DRLs look the good but I'm definitely not a fan of the $270 price tag.
                        I am thinking of doing what steelbalz has done here, mount Rigid Dually's instead (the price is about the same). Just not sure how to do it yet as I have not purchased the lights.
                        http://www.pradopoint.com/showthread...l=1#post330223
                          $169 on eBay http://www.ebay.com.au/itm/321118415653
                            That's a fair bit better than the RRP on Narvas website.
                              I contacted Narva for a pic of them lit up but they don't have anything! Bizarre or what? I will delve into the bowels this weekend and look at what the existing bracket looks like. The hole in the bar/fogs is 100mm more or less so there would be a 5mm gap around the outside. Also not sure how they will line up given the angle on the bar. Seems to be a few options but all about the same size. The ADR on DRLs for what it is worth says:
                              Must be fitted as a pair
                              At least 600mm centre to centre and not more than 510mm from the side of the vehicle (doesn't include mirrors)
                              White or yellow light visible from the front
                              Maximum of 25W total
                              Wired so they are off when any headlight (low or high beam) is on
                              The other option which I was thinking of was a decent 100mm driving lamp to light up the edges of the road in da bush! Again a few of these around including HID and LED variants.
