Rear bar advice
  • Rear bar advice
    Do any of you have a rear bar installed?
    I like the look of the Kaymar bar but the price is rediculous! Im thinking about a MCC bar.
    Do any of you have a MCC bar installed?
    I haven't got either but looking at them myself. From looking it seems you don't gain any extra departure angle from the MCC as it still uses the stock towbar. Suppose it depends on how much you value that
      Yes I noticed that.
      but the kaymar bar is nearly twice the price!
        I have the Kaymar on mine. Very happy with it. I picked it up at a 4wd / Camping show saved a bucket load of cash. Very happy with the build quality and the little things that come as standard ie brackets for light pole (mine came with the light as part of the deal).
        2008 Prado GXL D4D Auto Silver, 265/70x17 Mickythompson ATZ 4 ribs, ARB delux Bar Avenger Mako 9500 winch, TJM XGS Gold suspension, Poly airs, Safari Snorkel, Dual Battery system, Voltage Booster, Lightforce XGT lights, GME TX3100 UHF,ARB CKMA12 Compressor, ENZD special quad breather kit,Outback Draw system 1/2 Cargo Barrier,Kaymar duel wheel carrier,AJ120 Sliders, Taipan XP Exhaust, Twin E Lockers, Foxwing, Pioneer Platform.
          My bargain price is a little over 4k :!::x
            Yep, that's what they charge for it all fitted up. I would get one again in a heartbeat. If you take into account you don't need to fit a towbar it brings the price down a little, or pushes the price of the mcc up. Agree with the finishing touches, it just fits right and works without fuss or constant adjustments.
            [LEFT]Silver 150 Facelift
              Outback Accessories bar looks alright too, I'd like to see a side by side comparison with the Kaymar (pictures). What are the differences in clearance?
                I have been looking at rear bars mainly as I I want some rear protection when I drop off a ledge or something like that as I've come close to tearing my plastic bar off several times now. I would go for the spare tyre carriers but would only fit them when required for big trip. Does the Kaymar bar offer the type of protection I am talking about as I notice the original bar remains apart from the section where the new bar goes.
                  Definitely offers that protection, the original rear bumper is only really uses as infill panels, the kaymar wraps around from mudflap to mudflap. Using the wheel carrier all the time will remove the weight from the rear door and hopefully help the door hinges last longer.
                    I think i might go for the Kaymar bar for now then purchase a wheel carrier and jerry can holder later on. This should bring the price down to under $2500.00.
                      Thinking the same thing!
                        Hay guys. The Kaymar swing arms are $800 for each arm alone. So might be worth doing the maths to see if it is cheaper.
                        SOL.
                          SOL.
                          I had a look at the costings, it is about $200 +/- dearer if you buy the swing arms separate after the bar. I suppose the advantage is you can spread the cost out a little. If I am financial enough when I take the plunge I'll get the lot in one go!!
Name:	Kaymar rear bar comp 059.jpg
                            $1000 for a genuine bar or this. Choice was simple.
                            Crystal Pearl Altitude 150 Landcruiser Prado. TJM sensor bar, brush guard, side steps. KM2 BFG on GXL alloys. Kaymar bar, Drifta and MSA fridge slide. ARB locker and compressor, and MK11 compressor and fuel filter bracket.
                              Originally posted by Pearl150 View Post
                              [ATTACH=CONFIG]19984[/ATTACH]
                              Yep, I should have done it instead of a genuine bar!
