@Daz, I have contacted our WA Sales Rep. I hope to have a solution in the works ASAP.
rhino rack "back bone" roof rack system
For those that have fitted the Pioneer tray and have used it in anger, how have you found the durability? I have a frontrunner rack at the moment which has been across the CSR, Madigan Line a couple of times, French Line, etc., and has not missed a beat. I'm looking to get a longer rack through and I've got my eye on the pioneer 2128mm long model. Are the corner connector pieces made of plastic? How do they hold up? Any issues so far? Are the backbone mounts holding up okay?2010 GX Turbo Diesel
Originally posted by andoland View PostFor those that have fitted the Pioneer tray and have used it in anger, how have you found the durability? I have a frontrunner rack at the moment which has been across the CSR, Madigan Line a couple of times, French Line, etc., and has not missed a beat. I'm looking to get a longer rack through and I've got my eye on the pioneer 2128mm long model. Are the corner connector pieces made of plastic? How do they hold up? Any issues so far? Are the backbone mounts holding up okay?
Something I like about the pioneer though is the range of accessories that suit me and the slats are longitudinal not lateral which would (in theory) reduce wind noise.
Glad you asked the question....[I]A good friend will bail you out of gaol, a true friend will be sitting beside you saying, "wasn't that a blast"[/I] ...
White (sorry Glacier White) 2013, 150 D4D GX + the bits that will no longer fit in this space.
Longhorn,
My two reasons for looking at the pioneer rack over a new frontrunner are the extra length (2128mm vs 1968mm) and the pioneer is a little cheaper. Otherwise I'd be happy to have another frontrunner rack. Neither of these is a deal breaker, just reason to investigate the alternatives.
I've not found wind noise to be a significant issue on my frontrunner rack, but it is only 1700mm long so doesn't sit too far forward. It also came with a wind deflector.
Interesting comment about the accessories - the frontrunner seems to have more than the pioneer system, but in any case any that are designed to bolt onto the top of the slats should be interchangeable between the brands. One thing I did notice about the pioneer is that it doesn't have slots in the underside of the bars which is probably a non-issue for most people, but I have my awning brackets mounted on the underside to reduce overall vehicle height and if you want to store a slide out table under there (or say solar panels) the pioneer makes this difficult.
The other thing is that the frontrunner has rails right at the very edge for tying stuff to whereas the pioneer has a slot at what looks to be 50mm or so in from the edge where you would have to screw on tie down points so it would seem that you'd really loose a bit of space.
Gee, I really seem to be talking myself into another frontrunner here, if only it was slightly longer.
beatit99, thanks for the feedback. Good to know it is going strong. One of the vehicles I travelled with on the Anne-Beadell Hwy and other Len Beadell roads last year had an aluminium, full cage-style rack from one of the cheaper 4wd outlets and it collapsed onto his roof. We discovered that everyone of the legs had cracked and the welds had broken. Once we fixed it all up with fencing wire I reckon it was stronger than new!2010 GX Turbo Diesel
ORE at the Perth 4x4 show are doing 15% off Rhino gear guys. I ordered the 2100 long backbone platform for the GX today with free shipping to my door. Not a bad deal and Tim the sales manager has his 150 Series there with the backbone on it so that you can get a good look. Ill be interested to see how much noise I notice once I install it.
Originally posted by evltoy View PostI ordered mine on the weekend. I get it next week and paid 1300 with me picking it up an installing myself.
I have a sunroof on my 150 Altitude so it will be interesting to see if the open tilt will not be affected.
I am still deciding whether to go the 21 or the 19 especially now the backbone is out for both.
Originally posted by daz7 View PostMessage for Will:
I picked up my RTPB1 Backbone + 42102B (1928x1236) on 3rd Nov from the Welshpool depot in Perth. Unfortunately after fitting the backbone rails I have discovered the instructions are Issue03, and the Backbone does not fit the platform. It seems I have been given rails CA1466 & CA1467.
I will contact the retailer for this to see if I can arrange a swap. How can I determine if the Backbone box contains rails CA1626 & CA1627? These are not printed on the box, the only indication was a very small "Issue 03" on the instructions inside the box.
HaaHn
Originally posted by Selthy View PostI am looking for a low profile rack for my VX. Can someone who has installed one please measure the height and advise the height from the ground. I need to get my car under some low car parks.
Has anyone noticed an increase in noise since installing theirs?
(i dont have a lift yet)
I would love your opinion... rather urgently.
I just purchased (sort of) a 1928mm Backbone system. In WA. After the store installing the backbone rails and then trying to fit the tray, they noticed the holes for the bolts don't line up. They contacted the "WA State Manager" for Rhino and apparently the new rails are still a few weeks away to WA. I pointed out this thread and the part number and was told that the Rhino state manager said there is an error in the Rhino system. Disappointing as I now have rails on my roof and sealed (original rails have been removed) that do not fit the platform I purchased. And No Platform.
I now have one of 2 choices, instal the larger rack and pay extra, this is the solution I am considering or...
The store said they can drill new holes in the backbone system to accomodate the platform. I am not comfortable with this, although they called the State Manager for rhino again when I was there and they all feel this will be OK.
Your thoughts? I will be hunting for photos of the 2120mm platform on a prado.
Surely Rhino could upgrade you to the larger tray at their own cost given it is their incompatability.
I have the larger platform on my own PradoPrado 2014 Manual GXL, TJM T13 Bull Bar, Recovery Points, TJM Side Steps, TJM 9500 Winch, Airtec Snorkel, Lightforce 180SD LED Lights, TJM XGS Springs & Shocks 2" Lift, Toyo Open Country AT2, Hayman Towbar, Rhino Backbone and Platform, Tanami Drawers, Clearview drop slide, Engel 40L, Redarc Brake Controller, Hema Navigator, Kings Awning
Off Road Camper Trailer ~ 2014 Toolman Explorer Hard Floor
Originally posted by Selthy View PostI would love your opinion... rather urgently.
https://goo.gl/photos/pkHt2cDDtYGCJo296
https://goo.gl/photos/bUGZJLusHYJxxQyY7
https://goo.gl/photos/FRN2mSP832VyMHsLA
https://goo.gl/photos/5XVqf9TqhzYfWYNp8
