Re: Dual Battery System
Fitted the Auxillary battery bracket into the Prado 150, the battery goes in tomorrow. This bracket is for a N70 auxilliary battery. Some photos:
Before the mod (NOTE: This is a Diesel which has a different layout to the petrol as pictured in the above posting)
Mounting plate fitted. Note the airconditioning pipes have been moved about 50mm. You need to be careful that you dont bend the big pipe as it has a pipe in a pipe. The aircon people told me this pipe cannot be bent.
You need to make sure the little pipe going towards the radiator (bottom of the picture) does not contact any metal. I had to reposition mine a little to give it some clearance. Below is the part number for those chasing it.
I found it difficult to fit as there was a bit of pressure on the plate and the mounting holes did not seem to be precise. Took about 20 minutes. When I get the battery in and the cables hooked up will post a photo.
Nifty
Nifty
