GME TX3340 install
  • #31
    Hi Dave,
    Note in your buildup says you had the remote reprogrammed for the windows (a'la my Renault Scenic 2006) did you do this thru a dealer or elsewhere?
    Regards
    Andrew
    • #32
      Originally posted by pasc01 View Post
      Hi Dave,
      Regards
      Andrew
      I got it done by the dealer at the first service, just speak to them in the service department. There is another thread somewhere about other options that can be programmed by the dealer, if you do a search it should come up. I had the option whereby when you press and hold lock/unlock it winds up/down the windows. It is great for when you get out and realise the kids have left the windows down and saves having to turn the ignition back on again to wind the windows up.
      [b]--Dave[/b]
      [color=#4000BF]150 GXL D4D Auto, Ironman Suspension - 2" lift Foam Cell, GME TX3340 UHF, RustStop RS-4 electronic rust protection, Hayman Reese towbar, BFG AT's 265/65/17, Rhino Racks, ARB Awning, Sandgrabber Mats[/color]
      [url=http://www.pradopoint.com/viewtopic.php?f=38&t=8368][i]My Build Up[/i][/url]
      • #33
        Hey David
        Just a quick post to say THANK YOU! for the great DIY guide on the GME TX3340 install, I had completed mine over the weekend.
        Much appreciated buddy.
        • #34
          You're a legend - thanks for uploading all the detailed pics and information. Greatly appreciated as i'll be arranging for a ARB Bar to be installed in the next few and the GME unit you've got is the unit i was going to buy.
          • #35
            Hi David
            Just a quick post to say thank you for the great DIY guide on the GME TX3340 install. I have used many of your ideas to complete an install of a TX3540 in my rig today. Your thread certainly made it a lot easier! Check out my build if you are interested: http://www.pradopoint.com/showthread...3-D4D150-Build
            Michael
            [I][B]2013 Prado Auto D4D150[/B] - genuine towbar, genuine racks, ARB deluxe bar, tinting, GME TX3540 UHF[/I]
            [B]My Build:[/B] [URL="http://www.pradopoint.com/showthread.php?29633-Micklow-s-2013-D4D150-Build"]http://www.pradopoint.com/showthread.php?29633-Micklow-s-2013-D4D150-Build[/URL]
            • #36
              Originally posted by Micklow View Post
              Hi David
              No problems Michael. Nice build you have going on. Great to use sites like these !
              [b]--Dave[/b]
              • #37
                Thanks for the tutorial mates. Finally installed the Uniden UH7760NB on my Prado 150.
ID:	645644Click image for larger version
ID:	645645Click image for larger version
ID:	645646Click image for larger version
                • #38
                  I'm sad to say that on our 2014 GXL our radio won't fit into the little hole any more - they have added/moved a floor vent air conditioning pipe so that it goes down under the carpet there making the gap too small for the radio to squeeze through :-(
                  • #39
                    Hi wasafi... I also have the OEM nudge bar (with Lightforce LED light bar mounted on it) and have been considering installing the aerial on the nudge bar just like you. It is a simpler & cleaner install but I have been worried about the range with the aerial mounted in this place. My local installer, Electric Bug says like many others that height of aerial is more important for effective range.
                    They showed me pictures of an install on a 150 where they have run the aerial cable up side of windscreen and along roof rail ( under the plastic cover in the roof rail channel) and on to the side of one of the roof rail mounts. Looks clean and only needs stubby aerial. They also have a work around if you put on a Rhino platform. I'm reluctant because I don't want to drill holes in the roof mount.
                    How have you found reception mounting on the nudge bar? Did you try any other aerials?
                    • #40
                      Re ariels
                      Depending on what you are going to use it for will depend on what type you get
                      eg stubby aerial usually only 2 db good for around town and very short range
                      If you are going to travel in the country on undulating surface ie hills etc a 6 db is best and these around a metre in length and will give around 30 plus kilometre range
                      If you are going out in the desert where its completely flat you could go to a 12db or higher These are much longer in length
                      Generally most go for the 6db
                      On the bull bar works fine
